chrislich Posted October 21, 2009 Share Posted October 21, 2009 Well had my mot done last week. As usual I didn't realise that it had ran out until the day it was up and this happened to be a friday, so kwik fit just round the corner was easy especially as I was at work over the weekend. Picked up and was told it passed nicely, couple of small advisories but nothing major. Week later I'm driving along and my car fills with smoke, luckily I'm just round the corner from home so pull up there. Open the bonnet and smoke is flowing quite happily out from around the engine. Obviously living in the same area as my work I'm not calling 999 till I can see flames. Leave it for min and the smoke dies down so investigate. Seems to be a lot of oil splatter. Bloody idiots haven't put the dip stick back properly and oil has come out all over the manifold. Was annoyed but relived at the same time. So beware chris Quote Link to comment Share on other sites More sharing options...
Chris`I Posted October 21, 2009 Share Posted October 21, 2009 Woah, close one! Glad it was only the dipstick. Be sure to double check the dipstick itself, we have had at least one report of the seals going on them and can cause the same problems as if someone hasnt put it back in properly. Just to be sure this hasnt happened to you Quote Link to comment Share on other sites More sharing options...
Husky Posted October 21, 2009 Share Posted October 21, 2009 kwik fit are cowboys. frequently put thier 2 post ramps through the air suspension compressor on the underside of our range rovers. A simple task aligning a lifting arm to a chassis part but noooooooo... Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 21, 2009 Share Posted October 21, 2009 Why would Kwik Fit have your dipstick out for the MOT test? Quote Link to comment Share on other sites More sharing options...
tmJak Posted October 21, 2009 Share Posted October 21, 2009 KwiK Fit have some good and bad mechanics - depends who you get. I'm not sure why they would take the dipstick out either Quote Link to comment Share on other sites More sharing options...
Husky Posted October 21, 2009 Share Posted October 21, 2009 KwiK Fit have some good and bad mechanics - depends who you get. I'm not sure why they would take the dipstick out either maybe they thought they could check the exhaust emmisions there? Quote Link to comment Share on other sites More sharing options...
N!ck-z Posted October 21, 2009 Share Posted October 21, 2009 I took my vectra to kwik-fit (also a last minute job) for an mot. They returned it with numerous failures telling me it needed new discs and pads all round and a new front wishbone amongst other things (they quoted £700 for all the work). I took it to another respected local garage, new front pads and discs later it passed (total £140) with no problems at all. I can't nderstand how they get away with it! Quote Link to comment Share on other sites More sharing options...
chrislich Posted October 21, 2009 Author Share Posted October 21, 2009 I wondered why they would touch it but someone said about oil temp? They had actually pushed it down the side of the hole obviously thinking they had put it back properly Quote Link to comment Share on other sites More sharing options...
sketch Posted October 26, 2009 Share Posted October 26, 2009 yep, we do mot's at work and you do take the dip stick out to check the oil temp before doing smoke/emmsions tests, Quote Link to comment Share on other sites More sharing options...
sunset350z Posted October 27, 2009 Share Posted October 27, 2009 I've had no problems with Kwik fit near me in Bridgend. Regularly had my Zeds oil changed there as it only cost £39, and mot'd my banger there once, which passed no problem. Depends on the staff i suppose. I take my cars to R J Davies in Pontypridd, (not far from Pontypandy were Fireman Sam lives ) for my MOT's as they are very reasonable, and will even fit you in out of hours, even on a sunday Quote Link to comment Share on other sites More sharing options...
