jables Posted October 13, 2009 Share Posted October 13, 2009 Guys, I'm after a new suspension setup and need some advice I only use the car on the road (no track days) but feel the Z's handling could be tightened up. Something a bit stiffer, but crucially I really want to avoid lowering the car, if possible? Not really fussed about adjustability. Any thoughts? Chris Quote Link to comment Share on other sites More sharing options...
introspect Posted October 13, 2009 Share Posted October 13, 2009 To be honest with you, if you don't want adjustability and you want to keep standard ride height and you're not doing track days I'm not sure there's much benefit in upgrading the suspension. I find the standard setup more than adequate for general/fast road use. Hopefully others with an upgraded setup can offer their opinion too Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted October 13, 2009 Share Posted October 13, 2009 As has already been said, not much point in going to the expense of suspension upgrades if you don't won't to benefit from track use or lower ride height. You would possibly be better spending your money on a decent set of tyres such as Pilot Sports. Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted October 13, 2009 Share Posted October 13, 2009 +1..standard set up is IMO fine for general fast road use! If you want a bit more control and stiffness get some POLY BUSHES for the control arms and maybe upgrade the roll bar, oh and get some Viagra too Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted October 13, 2009 Share Posted October 13, 2009 if your trying to stiffen up the car without lowering it then go and get the full summit underbody bracing set, Rik sells them for about £450, it should take some of the roll out of the car and improve your cornering. Speaking to Eknoa who has this fitted and tracks his car says it makes a noticable difference to handling. i think its easier to hold the back end out and with more control. tighter into the corners and just generally sharper handling. PM ekona for more info i'm sure he'd be happy to fill you in Quote Link to comment Share on other sites More sharing options...
Adriank Posted October 13, 2009 Share Posted October 13, 2009 if your trying to stiffen up the car without lowering it then go and get the full summit underbody bracing set, Rik sells them for about £450, it should take some of the roll out of the car and improve your cornering. Speaking to Eknoa who has this fitted and tracks his car says it makes a noticable difference to handling. i think its easier to hold the back end out and with more control. tighter into the corners and just generally sharper handling. PM ekona for more info i'm sure he'd be happy to fill you in Another option is: Do the full car set of Whiteline Poly suspension bushs. This transforms the handling, and will not affect height, geometry or ride quality. I'd go firstly for this option, as the OEM bushs will be worn. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted October 13, 2009 Share Posted October 13, 2009 The option I would go for is some new anti rollbars. That'll sort you out nicely without breaking the bank. Body bracing is pointless unless on a track car, and bushes wont make as big a difference as ARBs and springs Springs will make a big difference too, but they all lower the car. Quote Link to comment Share on other sites More sharing options...
Ekona Posted October 13, 2009 Share Posted October 13, 2009 Body bracing is pointless unless on a track car I would humbly disagree: My car spends 90% of it's life on the road, and the bracing has made more of a difference than I ever thought possible. It gives you so much more feel from the chassis that you can push it further than you ever thought possible, confident in the knowledge that it'll give you more than enough warning for when anything starts to let go. That confidence alone is worth more than a few tenths wherever you are, road or track. Bear in mind I'm on stock suspension as well and I hate to think just how good the car would be with some really decent suspension on there... That said, and to answer the OPs question, I think that your suggestion of just doing the ARBs is a pretty good alternative as well. If you choose the right ones and don't go too stiff, then you'll actively increase the cornering ability of the car without suffering from wheels trying to jump off the road when one side hits a bump. Jables, if all you want to do is to go faster with more control then personally I'd spend the budget on tyres (I love the Michelin PS2s for their feel and wet handling charateristics, but these are proving hard to get hold of in the correct sizes recently so I would also look at the Vredestien Ultrac Sessantas), if you want more feel but with increased body stiffness then the Summit/ GT Spec bracing pack (same thing essentially) is the way to go, or if you just want a little sharper drive through the corners then the ARBs is a great solution. In an ideal world though, you'd do the lot and I'd argue that the car would be a whole lot better to drive than just sticking an expensive set of suspension on there, but that's another story... Quote Link to comment Share on other sites More sharing options...
z-man Posted October 13, 2009 Share Posted October 13, 2009 Fit KW Variant 3 coilovers and Cusco ARBs. The improvement is incredible. Handles like it's on rails! Quote Link to comment Share on other sites More sharing options...
Chris`I Posted October 14, 2009 Share Posted October 14, 2009 Ekona: Good feedback on the body bracing The reports I had heard before said it didnt do a lot for on the road. I beleive KW V3s lower the car by 20-30mm at their highest, so unfortunately I guess they would be out of the OPs specs. Not sure how much (if anything) BCs lower it, but they could be a good shout. Quote Link to comment Share on other sites More sharing options...
jables Posted October 14, 2009 Author Share Posted October 14, 2009 Great advice as always, cheers all I think I'll look into bracing and ARBs then, see if that makes a difference, and report back! Quote Link to comment Share on other sites More sharing options...
