Spacers and spoiler
V88 REG
Afternoon :thumbs:
Is there a link to find out how to fit spacers. their the 20mm Eibach kit on the Rays 18" alloys, i mena it cant be hard but just want to make sure.
Also i have bought the Envy Carbon front bumper cover thing. Just it just stick on?
Thanks a munch bunch :cold:
Spacers are easy peasy, just fit them like you would wheels then fit your wheels on top.
Bumper cover fits with double sided bonding tape or a bonding sealant.
Oh and on the rear hubs you will find a bolt sticking out, this just screws out, its there to prevent you putting the front wheels on the back by accident.
R
R
I thought it was the other way round - the bolt being on the front.
You will need to make sure the nuts on the spacers are tight otherwise they will come loose like mine did!! :scare: I recommend using either locktight or getting your local garage to do them up with an gun.
R
Possibly is on the front, it was a while since i did mine. If you can get hold of a torque wrech then use it if not, I did mine with the tyre wrench and they are fine as long as you do them up tight enough.
R
Does the 15mm spacer have a better handling than the 20mm. Wanna find out which is better before I get it. And do i need to get extra long bolts, coz of the extra width? Thx^^
i run 20mm and can't tell the difference, car feels just as planted
as for longer bolts what ever kit you get should have everything you need. but if your getting the eibach hubcentric ones they are best as the studs are already on the spacer, with holes for your original studs to go into and then bolt the spacer ontop. then with the new spacer studs you refit the wheel with your own nuts and jobs a goodun.
Please dont use a wheel/air gun to do the bolts up. You might overtighten them and worst case overload the bolts causing them to sheer or best case make them too tight to ever remove! Torque them up as you would a normal wheel, as per the specs they supply :)
:blush:
:blush:
Last time I got a puncture repaired they did the bolts up with a gun. When I came to remove the wheel again, I snapped my 1/4" to 3/8" adapter trying to get it off it was that tight. Took it to my trusted wheel place and we had to put their gun on full power to get it off. I dread to think how much torque had been put on the nut :headhurt: Torque wrench all the way, with incremental increases in torque is the best way to do it :thumbs:
thats alright they are coming off again in a few weeks when the wheels are refurbed ;) i'll get wheel genie to put them back on properly :)
Did you do it with a gun or by hand? By hand you wont have been ablet overtighten it much - unless you used something like a 3ft breaker bar! Its the guns on full power that are the problem :headhurt:
was the tyre fitters that did it, don't know what setting they had it on. would have been the same for the wheels
Lets hope they had some kind of torque limiter on there then or did it properly by just nipping them up and finishing off with a torque wrench :)
If its a tyre fitters then it was probably a torque set air gun, if they are fitting wheels without using correct torque settings then they shouldn't be fitting tyres at all.
R
You think that until you are bitten by them like I was. Even if they have torque limiters, they should be torquing it in a star pattern progressively. Never going straight to the max torque or round in a circle as most high volume (Quick fit, etc etc) places do :surrender:
