Hi guys,
Starting to get a long list of problems and set backs with the car. First of all I fitted the sound system and now the nearside wing mirror electrics dont work and the window doesnt retract completely. The windows are an easy fix if I can get be bothered getting round to it.
I fitted Hel brake lines, now the brake pedal seems dead spongy, so it needs bleeding again ... but I lost the locking wheel nut :angry: ... so I need to find a way to get them off and fit the new ones.
My belts are squeaking so much it is driving me crazy and I have mangled the main belt adjuster nut, so I will have to get a set of mole grips or something on that and get a new one and Im not even sure if it is the belts or the alternator :wacko: .
Im loosing my patience with it a wee bit, even though most of it is my fault lol.
HELP ME :surrender:
think its time you let the professionals do the work :lol::lol:
+1 :lol:
Sorry mate, your not having much luck. You should be able to buy a tool for removing the locking nut and just buy a set of after market nuts.
There is a proper procedure on here for changing brake fluid so you don't get air in the lines.
R
Aw mate you're having a 'mare :doh: Go get pished :drunk: and take it in to see someone on Monday :thumbs:
+1 thats the best idea iv heard all week Vik infact i might take your advice also haha :lol:
I know where your coming from mate.I attempted to remove my headlights was told it would take an hour,5 hours later I gave up.Demolished a box of lager and phoned a garage the morning after.
Pay someone to have the aggro and sit back it's easier and less stressful.
What she said! :lol:
Just bite the bullet and dump it on someone else to sort it all, you will feel SO much better!
Agree with the above BUT there is something nice about doing it yourself :thumbs:
I've had similar problems but mine was done by professionals!
first i had a nut round off on my spacers because some idiot at kwick fit over tightened them. (i needed to change the front wheel hub because the bearing was gone)
then after 3 hours of trying my mechanic cut it out but wrecked the spacer.
i then bought another pair of spacers and because they were 25mm instead of 20 i had them put on the back.
i also had the rear wheel bearing changed.
yesterday i was happy as larry driving my car and then i realised that when the steering is at 11o'clock im going straight,
so i realised that i need to spend another load of money to get the laser alignment done again. so a trip on monday to CS.
this morning i found a funny looking thing next to the rear wheel of my car.(on my driveway) picked it up, looked like a locking wheel nut but without the thread. looked at the wheel and basically the locking nut was broken. so now i have another problem with removing that from the stud! WTF is going on?
if i get the alignment done and then theres a load of banging going on afterwards to remove the remains of the lock nut then it might be knocked off again! :rant:
this is all made worse because i work away from home all week so im only here on weekends and monday mornings!!
sorry about the rant guys :blush:
Yeah I like trying it for myself and then put it into the garage if it goes a bit awry, I took your advice vik, the garage is getting it on Monday. But I feel a bit better it isn't just me that is ambitious but rubbish lol
