Trog Posted July 17, 2006 Share Posted July 17, 2006 My car is going back into Westway this week to have another go at the tracking (after tyre warranty) amongst other things (another clicky shaft etc..). Based on my previous experience, if you apply the right amount of toe-in on the front, the car will naturally centre itself as you you apply the throttle, BUT my Z never feels comfortable (if you know what I mean). If I make a very very small correction to the left, it will pull slightly left and likewsie, if I make a very very small correction to the right, it will pull slightly to the right. basically, I can never let go of the wheel on a flat road and expect it to drive in a straight line! Not that I do this, but you get the idea. Anyone else suffer the same problem and is my diagnosis correct (i.e. not enough toe-in). Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted July 17, 2006 Share Posted July 17, 2006 Trog said: My car is going back into Westway this week to have another go at the tracking (after tyre warranty) amongst other things (another clicky shaft etc..). Based on my previous experience, if you apply the right amount of toe-in on the front, the car will naturally centre itself as you you apply the throttle, BUT my Z never feels comfortable (if you know what I mean). If I make a very very small correction to the left, it will pull slightly left and likewsie, if I make a very very small correction to the right, it will pull slightly to the right. basically, I can never let go of the wheel on a flat road and expect it to drive in a straight line! Not that I do this, but you get the idea. Anyone else suffer the same problem and is my diagnosis correct (i.e. not enough toe-in). Sorry bud, not me!!! Quote Link to comment Share on other sites More sharing options...
AndyC Posted July 18, 2006 Share Posted July 18, 2006 Mine certainly doesn't do that mate, stays true on the straight, so sounds like you're right with your diagnosis Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 18, 2006 Share Posted July 18, 2006 I wonder if you have a bit of play in the steering rack. Just a thought Quote Link to comment Share on other sites More sharing options...
