Gearbox rattle
Mark@blueboys
Hi, just got my Z and have noticed that every time i turn the engine off, just as it stops theres a slight rattle noise from under the car, i know its comming from the gearbox, and it dosent do it if i stop the engine with my foot on the clutch.
Also if i have the window down i think the gears sound a bit rattley when changing from 1st to 2nd at slow speed, apart from the noises the gears feel perfect and the oil is cleen, just wondering if this is just a characteristic of the car?? and has anybody got the same noise?
Cheers!
Can't help you with the rattle at switch off but I also get a noise when changing gears at low speed (although more of a clonk than a rattle). I read somewhere on here that it's fairly normal behaviour so haven't worried about it.
Weird question but original or aftermarket knob?
There is normally a little brass cuff that fits in the knob on the OEM, sometimes this can work loose and cause a rattle that can carry on through to the gearbox and amplify!
Remove knob and have a look, or tighten up and see!
