Roo Posted October 5, 2009 Share Posted October 5, 2009 Right ho.... Before I ditched my old car i ripped all the components out of it, but before I sell em I want to check if its worth sticking them in the zed. So a bit of advice before i even consider riping things apart.. Front component speakers - What size are tweeters? Do they run off the headunit or pre-outs to a slaved amp? What is the rating (ohm and RMS/peak) Where are the crossovers? Are the bose better than Rainbow CMX 265 (kick varient if i remember correctly)? Sub woofer - Size? I have a JL V12W3D4 - would it fit? ( is it worth it) Also equaly output rating? And ran off head or are there pre-outs to a slave amp? kit I have kicking about also includes genesis profile 4 and a JL monoblock as well as co-axial 5x7 but what happens to them depends on if i can use em. lot of q's I know! any help or pointer appreciated! Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted October 5, 2009 Share Posted October 5, 2009 What size are tweeters? Not sure but 1" ones can normally be made to fit the surround Do they run off the headunit or pre-outs to a slaved amp? They run off the head unit or BOSE amp if you have one What is the rating (ohm and RMS/peak) SOD ALL lol Even run of the mill replacements are a step up] Where are the crossovers? They are built into the amp Are the bose better than Rainbow CMX 265 (kick varient if i remember correctly)? Very very much doubt it Sub woofer - Size? I have a JL V12W3D4 - would it fit? ( is it worth it) Also equaly output rating? And ran off head or are there pre-outs to a slave amp? A 12" will not fit the stock location no. IMO its not worth replacing the sub without replacing the amp as well. Head Unit output a special level (its between line level and phono) to the BOSE amp i.e. a sod to interface with but there are modules to do it Quote Link to comment Share on other sites More sharing options...
