paddy0d Posted October 4, 2009 Share Posted October 4, 2009 Hi, as above - I understand some of the later versions of the 350Z have revised plenums with less restriction to the airflow for the front cylinders. Is it possible to one of these on an older 03 Z? Thanks Paddy Quote Link to comment Share on other sites More sharing options...
clarkie34 Posted October 4, 2009 Share Posted October 4, 2009 I thought the plenum on the revup is the one with problems with air flow to the front 2 cylinders.That's why it feels it has less torque. Just get a spacer for yours. Quote Link to comment Share on other sites More sharing options...
Stew Posted October 5, 2009 Share Posted October 5, 2009 An MY03 needs a spacer. For a rev up a spacer coupled with an MREVII will net the best gains. The plenum in the MY03 offers the best flow I believe. Quote Link to comment Share on other sites More sharing options...
sunset350z Posted October 5, 2009 Share Posted October 5, 2009 Are you getting the plenum mixed up with the lower collector? The plenum chambers are virtually identical between the 2 models, apart from a few bolt holes. The difference is in the lower collector. The up-rev collector has shorter inlets, which would give you slightly less torque. You'll have absolutely no benefit fitting an up-rev lower collector whatsoever. If you had an up-rev engine then a good mod is to fit a MREV2 from a MY03, which has had the front 2 inlets machined down, and a spacer Quote Link to comment Share on other sites More sharing options...
paddy0d Posted October 5, 2009 Author Share Posted October 5, 2009 Great - thanks Quote Link to comment Share on other sites More sharing options...
