Changing rear wiper
ZedJohn
Hello,
I've bought a new wiper blade and tried to remove the old one and it won't budge. I know there's not much travel lifting it away from the rear windscreen, but is it just a case of brute force to unclip the blade from the arm?
Thanks
at the pivot point of the rear wiper arm the the cover that sits over it should slide back about 3-5 mm, which then allows the rear arm up for changinging cleaning etc.
i know this as huskies does it, but mine doesn't as it seems to have seized on.
have a try but if its not budging then leave it and go for plan B
  • 5 months later...
I had no luck with this. The lower cover slid back ok but the upper arm would still not lift above a few centimetres :dry: . I managed to flex the wiper arm just enough to get the new wiper in.
Was a bugger to fit, hopefully won't have to do it again!
