matth76 Posted October 3, 2009 Share Posted October 3, 2009 Hi Done a few searches but can't find an answer to this - what is the stock bore diametre of factory exhaust? Reason I ask is because I have seen a cat back stainless exhaust (Japspeed K2) which I like the look of and it says it is 3" bore diameter. How does this compare to the standard factory exhaust? Thanks for any help and info. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 4, 2009 Share Posted October 4, 2009 HiDone a few searches but can't find an answer to this - what is the stock bore diametre of factory exhaust? Reason I ask is because I have seen a cat back stainless exhaust (Japspeed K2) which I like the look of and it says it is 3" bore diameter. How does this compare to the standard factory exhaust? Thanks for any help and info. The stock exhaust is smaller than 3" but as long as the flanges are the oem size then it will marry up to the cats or Y section. Quote Link to comment Share on other sites More sharing options...
djtimo Posted October 4, 2009 Share Posted October 4, 2009 The stock pipe work is 2.36Inch mate! Quote Link to comment Share on other sites More sharing options...
Stew Posted October 4, 2009 Share Posted October 4, 2009 Just to be on the same page here, are the quoted diamaters ID or OD? I'm sure it would make next to no difference but just to keep it consistent! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 4, 2009 Share Posted October 4, 2009 The OD of the stock pipe is 60mm The ID of the stock pipe is 58mm The CTC of the front flange is 105mm The CTC of the rear flange is 102mm The CTC of the front Y flanges are 97mm Quote Link to comment Share on other sites More sharing options...
Stew Posted October 4, 2009 Share Posted October 4, 2009 The OD of the stock pipe is 60mmThe ID of the stock pipe is 58mm The CTC of the front flange is 105mm The CTC of the rear flange is 102mm The CTC of the front Y flanges are 97mm Ask and Alex shall answer! Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted October 4, 2009 Share Posted October 4, 2009 The OD of the stock pipe is 60mmThe ID of the stock pipe is 58mm The CTC of the front flange is 105mm The CTC of the rear flange is 102mm The CTC of the front Y flanges are 97mm so whats that in inches then don't worry i can do the conversions Quote Link to comment Share on other sites More sharing options...
Beavis Posted October 4, 2009 Share Posted October 4, 2009 The OD of the stock pipe is 60mmThe ID of the stock pipe is 58mm The CTC of the front flange is 105mm The CTC of the rear flange is 102mm The CTC of the front Y flanges are 97mm so whats that in inches then don't worry i can do the conversions 25.4mm per inch Did not google it either been in engineering and all that Quote Link to comment Share on other sites More sharing options...
matth76 Posted October 4, 2009 Author Share Posted October 4, 2009 Cheers guys. The Japspeed K2 appears to be exactly the same bore as the Nismo system. Do you think I will lose low down power fitting an exhaust which is 3" bore? I was thinking of getting the Japspeed Y-Pipe too because I have heard the stock Y-Pipe is quite restrictive. Does the Y-pipe contain the two cats and O2 sensors? Do I retain my O2 sensors or do I need to buy new ones? Thanks again. ps I was down at Santa Pod today - saw some nice 350's in the stand - lovely yellow one with lambo style doors. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted October 4, 2009 Share Posted October 4, 2009 y pipe will connect to your stock cats and all the O2 sensors are mounted into the cats, no sensors after that. Quote Link to comment Share on other sites More sharing options...
Adriank Posted October 5, 2009 Share Posted October 5, 2009 You wont lose power with a bigger bore. I made good power on the RR day, and the Buddy Club i have is 3.5" bore on the main tube... Quote Link to comment Share on other sites More sharing options...
