HOW DO THE Z SIDE BADGES COME OFF?
jerry3167
heat gun to get you started, use a knife to lift the edge enough to get your fingers under, and then prise with fingers, don't use the knife for the whol ejob, as you run a high risk of slipping and scratching paint work. ;)
and its held on with very strong adhesive foam tape and 2 pins that fit into locating holes.
I was messing under the arches when I removed mine so pushed them out from the back by taking the rear arch liner off from the front wheel. I also had to wire mine up as have the LED badges so it was easier for me to do that. Only the adhesive holding mine on, the pins are just for locating it in the right place from what I could see. :thumbs:
