StokieShinobi Posted September 25, 2009 Share Posted September 25, 2009 Hi all Im buying the P3 service kit and got the JWT pop charger. However, there is no fuel filter or pollen filter included. Do thee need servicing / changing? Does anyone know where I can buy them from? I can get the full service done then Thanks ppl!! Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted September 25, 2009 Share Posted September 25, 2009 Zed doesn't have a pollen filter. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted September 25, 2009 Share Posted September 25, 2009 Zed doesn't have a pollen filter. +1 - also not sure when the fuel filter is changed - if at all - but I guess it should be? Dont have my logbook with me to check Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted September 25, 2009 Share Posted September 25, 2009 Service book says that fuel filter is maintenance free on CR/QR/QG engines, else replace every 36,000 miles. Quote Link to comment Share on other sites More sharing options...
Darren-B Posted September 25, 2009 Share Posted September 25, 2009 Fuel filter is a service free part, suppose it just pumps all the S*** into the engine Quote Link to comment Share on other sites More sharing options...
StokieShinobi Posted September 25, 2009 Author Share Posted September 25, 2009 That is odd, a filter that doesnt need changing. Saves the pennies though I guess Thanks guys Quote Link to comment Share on other sites More sharing options...
StokieShinobi Posted October 8, 2009 Author Share Posted October 8, 2009 Well.... Oil was changed. Oddly 5 quarts went in leaving oil inbetween min and max line - ONLY 3 quarts came out. Is this usual to be so low on oil? Only had the car a month so good job its been serviced asap really Quote Link to comment Share on other sites More sharing options...
mike@mjpauto Posted October 8, 2009 Share Posted October 8, 2009 Fuel filter is effectively the gauze screen on the pick-up in the tank! Quote Link to comment Share on other sites More sharing options...
Ebized Posted October 8, 2009 Share Posted October 8, 2009 Well.... Oil was changed. Oddly 5 quarts went in leaving oil inbetween min and max line - ONLY 3 quarts came out. Is this usual to be so low on oil? Only had the car a month so good job its been serviced asap really You must be as old as me to be quoting quarts 5 quarts = 5.68 litres, which is nearly 1 litre over the 4.7 litres required for an oil and filter change (4.4 litres if no filter change). But I presume you might mean litres? If your car is an MY06 model (296 bhp) then some are known to use oil and should be checked regularly. Keep an eye on the oil pressure guage - if you start to notice a fall-off in pressure or slightly eractic needle movement then the oil level might be getting low. Check the oil level regularly - the dipstick is a pain to use - best done when car has been standing for some time on level ground. MY03 models (with the 276 bhp engine) are not really known to use oil between services. Not sure about the MY07 (309 bhp engines) - don't recall anyone having any oil issues with that model. Quote Link to comment Share on other sites More sharing options...
StokieShinobi Posted October 8, 2009 Author Share Posted October 8, 2009 Well.... Oil was changed. Oddly 5 quarts went in leaving oil inbetween min and max line - ONLY 3 quarts came out. Is this usual to be so low on oil? Only had the car a month so good job its been serviced asap really You must be as old as me to be quoting quarts 5 quarts = 5.68 litres, which is nearly 1 litre over the 4.7 litres required for an oil and filter change (4.4 litres if no filter change). But I presume you might mean litres? If your car is an MY06 model (296 bhp) then some are known to use oil and should be checked regularly. Keep an eye on the oil pressure guage - if you start to notice a fall-off in pressure or slightly eractic needle movement then the oil level might be getting low. Check the oil level regularly - the dipstick is a pain to use - best done when car has been standing for some time on level ground. MY03 models (with the 276 bhp engine) are not really known to use oil between services. Not sure about the MY07 (309 bhp engines) - don't recall anyone having any oil issues with that model. Thanks for the info, much appreciated! I followed the guide here: http://my350z.com/forum/repairing-and-d ... -pics.html ... which said to use all 5 quarts, I got about 4 and a half in. I have 5 quarts of the Royal Purple Oil; quite enjoy how it is actually purple http://www.z-store.co.uk/index.cfm?fuse ... rentCat=38 I have a 54 plate 350 so perhaps it is odd how it has used much oil. The oil pressure gauge was indeed bouncing around a lot - but i didnt know if this was normal as I've not long had the car. It does however seem more stable now not fluctuating as much. Thanks for the help and advice all! Quote Link to comment Share on other sites More sharing options...
