3FIDDYZ Posted September 17, 2009 Share Posted September 17, 2009 for those that were just discussing this in the for sale thread.. Available from zstore in the US, but i seem to remember Envy can get them... Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted September 18, 2009 Share Posted September 18, 2009 for those that were just discussing this in the for sale thread.. Available from zstore in the US, but i seem to remember Envy can get them... I'm sure we can yes, will try and stick one on our next order to take a look at. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 18, 2009 Share Posted September 18, 2009 defo interested Quote Link to comment Share on other sites More sharing options...
SunZed Posted September 18, 2009 Share Posted September 18, 2009 Looks quite good. Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted September 18, 2009 Share Posted September 18, 2009 We was on about making a CF version of it Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 18, 2009 Author Share Posted September 18, 2009 We was on about making a CF version of it Daft question maybe, buts whats the point? Sits behind the grill and you cant see it!! must be easied and cheaper to do one in plastic? Quote Link to comment Share on other sites More sharing options...
Darren-B Posted September 18, 2009 Share Posted September 18, 2009 Its all about the carbon, Im sure you will see it when the bonnets up Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 18, 2009 Author Share Posted September 18, 2009 Its all about the carbon, Im sure you will see it when the bonnets up Not if you got a carbon air dam!! as it will sit under it... (Cant understand whats up with me!! Saying something shouldnt be made in carbon!!! Must be ill!) Quote Link to comment Share on other sites More sharing options...
Pimm Posted September 18, 2009 Share Posted September 18, 2009 I would like one if they are cheap enough Quote Link to comment Share on other sites More sharing options...
andymc Posted September 18, 2009 Share Posted September 18, 2009 Mark - this is what I need for my Nismo issue .... do they make them for Dual intake motors ? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted September 18, 2009 Share Posted September 18, 2009 I'm not convinced for pop charger/K&N type intakes these will make much difference. For a sealed unit (ala OEM) I can see it will help get more air into the airbox, but I cant see it doing much for popcharger given when you are moving airflow already forces air up that way. Any notion of "ram air" is balls given the unit isnt sealed so it wont presurise anything. Ramair only really works on very few cars and bikes. I remember when my R6 came with it, and they reckon its only good for a bit more power above 60MPH. What I have noticed is that there are bits of trim behind our grille which when removed could aid in airflow, but need to look at it some more Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 18, 2009 Author Share Posted September 18, 2009 Mark - this is what I need for my Nismo issue .... do they make them for Dual intake motors ? Not sure but I had an idea for yours!!! Speak on Sunday!!! Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 18, 2009 Author Share Posted September 18, 2009 I'm not convinced for pop charger/K&N type intakes these will make much difference. For a sealed unit (ala OEM) I can see it will help get more air into the airbox, but I cant see it doing much for popcharger given when you are moving airflow already forces air up that way. Any notion of "ram air" is balls given the unit isnt sealed so it wont presurise anything. Ramair only really works on very few cars and bikes. I remember when my R6 came with it, and they reckon its only good for a bit more power above 60MPH. What I have noticed is that there are bits of trim behind our grille which when removed could aid in airflow, but need to look at it some more I have the typhoon with a pop charged and it does make a difference on air and temp... drove with it removed and the readings with the camp2 were less air and more heat without the tube... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted September 18, 2009 Share Posted September 18, 2009 I'm not convinced for pop charger/K&N type intakes these will make much difference. For a sealed unit (ala OEM) I can see it will help get more air into the airbox, but I cant see it doing much for popcharger given when you are moving airflow already forces air up that way. Any notion of "ram air" is balls given the unit isnt sealed so it wont presurise anything. Ramair only really works on very few cars and bikes. I remember when my R6 came with it, and they reckon its only good for a bit more power above 60MPH. What I have noticed is that there are bits of trim behind our grille which when removed could aid in airflow, but need to look at it some more I have the typhoon with a pop charged and it does make a difference on air and temp... drove with it removed and the readings with the camp2 were less air and more heat without the tube... Interesting. Was that at all speeds or just higher ones? I might go get a normal intake flexitube and add it to mine if thats the case Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 18, 2009 Author Share Posted September 18, 2009 I'm not convinced for pop charger/K&N type intakes these will make much difference. For a sealed unit (ala OEM) I can see it will help get more air into the airbox, but I cant see it doing much for popcharger given when you are moving airflow already forces air up that way. Any notion of "ram air" is balls given the unit isnt sealed so it wont presurise anything. Ramair only really works on very few cars and bikes. I remember when my R6 came with it, and they reckon its only good for a bit more power above 60MPH. What I have noticed is that there are bits of trim behind our grille which when removed could aid in airflow, but need to look at it some more I have the typhoon with a pop charged and it does make a difference on air and temp... drove with it removed and the readings with the camp2 were less air and more heat without the tube... Interesting. Was that at all speeds or just higher ones? I might go get a normal intake flexitube and add it to mine if thats the case All mate, tested over a weekend, saturday with, sunday without, motorway, backroads and town, same routes... even the way my front plate is fitted has an effect (for the worse!!) on the ammount of direct air... flexi's are worth a go for a test... but I would try and find some sort of scoop to max the volume... you could make one out of some plastic glued together I suppose to "ram" the air up... Quote Link to comment Share on other sites More sharing options...
