narcotix Posted September 17, 2009 Share Posted September 17, 2009 Ok so now I am even more confused ... Whats the difference between "CPS A Circuit Malfunction" and "CPS Circuit Malfunction" ? I ordered a Crank Position Sensor from Nissan yesterday and will be collecting it today after work ... have I got the wrong part then? When I spoke to the guy in the parts department he said there was only one Crank Position Sensor on the car ... Quote Link to comment Share on other sites More sharing options...
shire350Z Posted September 17, 2009 Author Share Posted September 17, 2009 There is only one crank position sensor but two cam position sensors iv gone for that option and there being fitted tomorrow so ill hopefully be at CS if they fail it will be in to nissan with the car Quote Link to comment Share on other sites More sharing options...
narcotix Posted September 17, 2009 Share Posted September 17, 2009 I think in your case it probably is down to the Cam Position Sensors as your car was cutting out while driving etc .. I think as mine hasn't cut out on me at any point yet, and threw up a P0335 code it is most likely the Crank Position Sensor ... What I am getting confused about is the difference between the "CPS A Circuit Malfunction" and "CPS Circuit Malfunction" ... Woudn't replacing the Crank Position Sensor resolve any issues with both these errors if there were any? Quote Link to comment Share on other sites More sharing options...
shire350Z Posted September 17, 2009 Author Share Posted September 17, 2009 Would.nt have a clue buddy now you'v bought the item fit it and if it resolve's your issue great if not get it to nissan Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 17, 2009 Share Posted September 17, 2009 What I am getting confused about is the difference between the "CPS A Circuit Malfunction" and "CPS Circuit Malfunction" ... I am guessing its the letter "A".... Sorry Quote Link to comment Share on other sites More sharing options...
narcotix Posted September 17, 2009 Share Posted September 17, 2009 Ok just picked up the part from Nissan and was advised that it is non-refundable as it's an electric component Hope it does the trick ... I've got quite a few Zed related expenses comming up in a month ( P3 Service, Tax and MOT ) so would like to minimise the cost of this repair ... Gonna see if CS can arrange to fit me in sometime sooon! Shire, let me know how it goes with your Zed ... Hope we both have it sorted for the weekend ... Quote Link to comment Share on other sites More sharing options...
shire350Z Posted September 17, 2009 Author Share Posted September 17, 2009 will to and i do to buddy good luck Quote Link to comment Share on other sites More sharing options...
Cal Posted January 15, 2013 Share Posted January 15, 2013 (edited) Thread resurrection! Did you guys solve your issues? Currently have an 03 import which is running very rough, engine management light ON, SLIP light ON and VDC light ON... It did go through an intermittent phase on running fine with just the management light on, but that seems to have passed and only runs rough with the 3 lights on now. A friends OBDII wouldn't read the code - I have a friend with 'Nissan Consult 2' but is a fair distance away, will that work on imports?? Hoping for as cheap a fix as possible as I'm beyond skint after Christmas! Ho ho ho Edited January 15, 2013 by Cal Quote Link to comment Share on other sites More sharing options...
KC350Z Posted January 15, 2013 Share Posted January 15, 2013 Thread resurrection! Did you guys solve your issues? Currently have an 03 import which is running very rough, engine management light ON, SLIP light ON and VDC light ON... It did go through an intermittent phase on running fine with just the management light on, but that seems to have passed and only runs rough with the 3 lights on now. A friends OBDII wouldn't read the code - I have a friend with 'Nissan Consult 2' but is a fair distance away, will that work on imports?? Hoping for as cheap a fix as possible as I'm beyond skint after Christmas! Ho ho ho You need a diffrent reader for JDM cars someone on here said about having one with lick to buy them ill see if i can find thread as it was not long ago Quote Link to comment Share on other sites More sharing options...
KC350Z Posted January 15, 2013 Share Posted January 15, 2013 not sure how do put a link on here but goto JDM import page and its in there hope this helps Quote Link to comment Share on other sites More sharing options...
Ebized Posted January 15, 2013 Share Posted January 15, 2013 not sure how do put a link on here but goto JDM import page and its in there hope this helps This one? http://www.350z-uk.com/topic/66032-jdm-jobd-code-reader-update/ Quote Link to comment Share on other sites More sharing options...
Ricey Posted January 15, 2013 Share Posted January 15, 2013 Thread resurrection! Did you guys solve your issues? Currently have an 03 import which is running very rough, engine management light ON, SLIP light ON and VDC light ON... It did go through an intermittent phase on running fine with just the management light on, but that seems to have passed and only runs rough with the 3 lights on now. A friends OBDII wouldn't read the code - I have a friend with 'Nissan Consult 2' but is a fair distance away, will that work on imports?? Hoping for as cheap a fix as possible as I'm beyond skint after Christmas! Ho ho ho Cal didn't you end up having a new engine in your car after to bought it?! Has this one gone too? Quote Link to comment Share on other sites More sharing options...
marzman Posted January 15, 2013 Share Posted January 15, 2013 From DBlock's page that Colin linked to - buy this Cal and read the code, then post the results back here and people should be able to point you in the right direction. http://www.ebay.co.uk/itm/OBDMATE-OM500-Scan-Tool-OBD-II-JOBD-Code-Reader-/160918631423?pt=UK_Diagnostic_Tools_Equipment&hash=item25777f73ff Quote Link to comment Share on other sites More sharing options...
M13KYF Posted January 15, 2013 Share Posted January 15, 2013 Thread resurrection! Did you guys solve your issues? Currently have an 03 import which is running very rough, engine management light ON, SLIP light ON and VDC light ON... It did go through an intermittent phase on running fine with just the management light on, but that seems to have passed and only runs rough with the 3 lights on now. A friends OBDII wouldn't read the code - I have a friend with 'Nissan Consult 2' but is a fair distance away, will that work on imports?? Hoping for as cheap a fix as possible as I'm beyond skint after Christmas! Ho ho ho Have you checked the battery. It can cause some weird things and with it being winter they show up more as battery is under more load. Mike Quote Link to comment Share on other sites More sharing options...
Cal Posted January 16, 2013 Share Posted January 16, 2013 Cheers, KC350Z, Ebized, Marzman... I did Ricey, Lee sorted it for me... I very much doubt the engine has gone, from what I've read it has all the signs of a faulty crank sensor... But a few people have had similar symptoms with cam sensors. My problem lies in lack of funds, so can't afford to be playing the lottery buying sensors... I have a mate who lives an hour away with Nissan Consult 3, so I'm just trying to twist his arm to come down. Failing that, I guess I'll have to buy the JOBD. Will get the battery checked just incase, cheers Mike Quote Link to comment Share on other sites More sharing options...
Cal Posted February 21, 2013 Share Posted February 21, 2013 All fixed for me finally - was an ignition coil that had gone! Quote Link to comment Share on other sites More sharing options...
KC350Z Posted February 22, 2013 Share Posted February 22, 2013 Glad you got it sorted 1 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted February 22, 2013 Share Posted February 22, 2013 cool, thanks for the update 1 Quote Link to comment Share on other sites More sharing options...
