Jammy007 Posted September 4, 2009 Share Posted September 4, 2009 Does anyone know how to remove the window guide that runs along the top of the passenger side door (bottom of the window when its closed). I can only see one screw when the door is open & I've been told it slides off, but I've pulled it quite hard and it hasn't budged. The replacement part I've got doesn't have another other fixing holes so what the hells keeping mine on the car? Looks as if its maybe tucked under the black plastic fascia for the wing mirror and if so then how do I remove this? Cheers, Jamie Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 4, 2009 Share Posted September 4, 2009 Have you taken off the door card? The wing mirror facia can only be taken off when the card is removed IIRC.. Removal here.... http://liljerk.morpheus.net/350Z/front_speakers/ Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 4, 2009 Share Posted September 4, 2009 full service manual here. viewtopic.php?f=35&t=2945 Quote Link to comment Share on other sites More sharing options...
Madmarky Posted September 4, 2009 Share Posted September 4, 2009 3FIDDYZ said: Have you taken off the door card? The wing mirror facia can only be taken off when the card is removed IIRC.. Removal here.... http://liljerk.morpheus.net/350Z/front_speakers/ Yeah im pretty sure it clips under the bit that has the tweeter in and then just should slide off, im sure the guides will help tho Quote Link to comment Share on other sites More sharing options...
Jammy007 Posted September 4, 2009 Author Share Posted September 4, 2009 Wow, its the full door card off on the inside jobby. Here's me thinking I could do it on my 30 minute dinner break just by undoing one screw and sliding it off the door....... Oh well that'll fill some time if it stays fair on saturday. Thanks everyone and big thanks to mr impossible for the heads up on the service manual Quote Link to comment Share on other sites More sharing options...
M13KYF Posted September 4, 2009 Share Posted September 4, 2009 Mr Incredible please Quote Link to comment Share on other sites More sharing options...
Jammy007 Posted September 4, 2009 Author Share Posted September 4, 2009 Haha my apologies! don't know where Mr. Impossible came from Quote Link to comment Share on other sites More sharing options...
Beavis Posted September 4, 2009 Share Posted September 4, 2009 M13KYF said: Mr Incredible please Quote Link to comment Share on other sites More sharing options...
Jammy007 Posted September 4, 2009 Author Share Posted September 4, 2009 Where it says in one of the guides to remove the screw under the door handle, careful - don't lose it..... What happens if you lose it i.e. thinking you can get your fingers in to retrieve it and it drops down behind the door card. Can it be retrieved upon removal of the door card? and if so I'm assuming it won't be able to fall out until the door card is removed. I'm assuming everyone used a magnetic screw driver and socket for removal of the screws on the passenger side door?! I'm giving up today anyways...... after calling Mike, Mr. Impossible and now this! Quote Link to comment Share on other sites More sharing options...
Jammy007 Posted September 5, 2009 Author Share Posted September 5, 2009 Woohoo I've finally done it, its alot easier than I thought, although still haven't put the screw back in place behind the door handle until i get a magnetic screw driver. Thanks for the help guys works a treat Quote Link to comment Share on other sites More sharing options...
