Tonser Posted September 1, 2009 Share Posted September 1, 2009 Hi The aluminium trims on my steering wheels trims are a bit scuffed up - I guess the previous owner wore rings, and held the wheel there Anyhows, as I'm getting the rear strut cover, and door switch panels refinished in Kuro, I'm going to have the aluminium trims done in Kuro too The only problem is the lettering for the steering wheel controls. Its only 2.5mm tall, so I'm wondering the best way to replace it ? I can match the font, and lay it out, but after that its tricky. A friend can do vinyl lettering but hes not sure he can go that small, and I think the vinyl itself will be too thick. Theres also white letraset transferrs available, but lining up each letter perfectly with the next will be a nightmare. Anyone have any other ideas ? Thanks Tony Quote Link to comment Share on other sites More sharing options...
srobrien Posted September 1, 2009 Share Posted September 1, 2009 PM rtbiscuit he is the vinyl guru on here R Quote Link to comment Share on other sites More sharing options...
Darren-B Posted September 1, 2009 Share Posted September 1, 2009 simples buy a std wheel thats in good condition and leave it alone Quote Link to comment Share on other sites More sharing options...
Chris`I Posted September 1, 2009 Share Posted September 1, 2009 simples buy a std wheel thats in good condition and leave it alone Not as mad as people might think. I got a wheel off eBay, much better condition than mine, so going to get it retrimmed and use the better looking alu bits too Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 1, 2009 Share Posted September 1, 2009 he did speak to me, i was the the "friend" like i said before i'm not sure i can cut that small, my best bet would be the letraset, if you use a piece of masking tape as a guide it makes life alot easier. and then you can take it off after. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted September 1, 2009 Share Posted September 1, 2009 How about asking the carbon boys (scottsoulby, Carbon Coops) about having the alu bits made in CF, and then instead of having the lettering painted/stickered on, have the lettering stamped into the gelcoat and then filled with white paint. That should last, shouldn't it? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted September 1, 2009 Share Posted September 1, 2009 good call BM, its something i'd like. i looked inot taking mine off and carbon wrapping them, but its just such a fiddly job, would rather have a decent cover to put over. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted September 1, 2009 Share Posted September 1, 2009 I would buy the 2007-2009 steering wheel switches and covers. The lettering it on the buttons / switches so you wouldn't have to do any stickers for them. Would look a lot neater. Contact Mr Lizard as I know he has a steering wheel in mint condition. I have one in stock also but in no rush to sell mine. I'm sure it will look great whatever you do Quote Link to comment Share on other sites More sharing options...
Tonser Posted September 1, 2009 Author Share Posted September 1, 2009 Thanks guys. Yep I'd spoken with rtbiscuit on this, plus I have another friend who does vinyl, but also thinks it would be too small. R35Lee, sounds like a good plan - are the 07-09 wheels and steering wheel controls interchangable with a 2004 car ? Cheers Tony Quote Link to comment Share on other sites More sharing options...
Tonser Posted September 1, 2009 Author Share Posted September 1, 2009 Unfortunately Mr Lizaed has sold his, so .... - can anyone confirm that the 07-09 wheels are interchangable - and has anyone got one for sale ??? Thanks Tony Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted September 9, 2009 Share Posted September 9, 2009 somebody call?? ill certainly look into it for you, do the covers come off the steering wheel? if so,,, how? Quote Link to comment Share on other sites More sharing options...
Ian Posted September 9, 2009 Share Posted September 9, 2009 somebody call?? ill certainly look into it for you, do the covers come off the steering wheel? if so,,, how? My wheel is in the garage, i'll have a look later & see Quote Link to comment Share on other sites More sharing options...
Tonser Posted September 9, 2009 Author Share Posted September 9, 2009 Hi Scott Yep the covers come off, but you have to take the wheel off to do it unfortunately. Its a case of airbag off, then wheel off so you access the trim screws and get the trims off. If you have steering wheel controls, the trims clip onto the actual switch housings. If you could make them in CF we'd still have the problem of the decals though. I'm looking into having decals made to go on the actual switches themselves rather than the trims - like the 07-09 wheels I believe. Tony Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted September 9, 2009 Share Posted September 9, 2009 thanks mate, could you take a couple of pics front and back so i can see how they fit on? Quote Link to comment Share on other sites More sharing options...
sunset350z Posted September 9, 2009 Share Posted September 9, 2009 Theres a torx screw on the back for each cover, undo them and the covers should fall off. Quote Link to comment Share on other sites More sharing options...
Tonser Posted September 9, 2009 Author Share Posted September 9, 2009 My 04 UK GT is different, as it has the steering wheel controls. 2 Torx security screws hold the airbag in place, so once theyre undone the airbag comes off (disconnect the wire too). You can then pull the other electrical connector in the steering wheel, undo the 19mm steering column nut, and pull the wheel off. 3 small philips screws hold the trim on the back of the wheel, and once that is taken off you can get to the the final 2 screws that hold the steering wheel switched in place. The aluminum trims clip in to these switch housings. I havent tried it yet, but I reckon you can refit everything to the car without the ali trims (I have done this bit) then I think the ali trims will just clip on without removing anything. I'll let you know when I get mine back from the painters. Tony Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted September 9, 2009 Share Posted September 9, 2009 My 04 UK GT is different, as it has the steering wheel controls. 2 Torx security screws hold the airbag in place, so once theyre undone the airbag comes off (disconnect the wire too). You can then pull the other electrical connector in the steering wheel, undo the 19mm steering column nut, and pull the wheel off. 3 small philips screws hold the trim on the back of the wheel, and once that is taken off you can get to the the final 2 screws that hold the steering wheel switched in place. The aluminum trims clip in to these switch housings. I havent tried it yet, but I reckon you can refit everything to the car without the ali trims (I have done this bit) then I think the ali trims will just clip on without removing anything. I'll let you know when I get mine back from the painters. Tony Which I am still hoping will be this weekend!! !!! Quote Link to comment Share on other sites More sharing options...
Tonser Posted September 9, 2009 Author Share Posted September 9, 2009 Cool if they are though I'm not sure if I'm gonig to make envy on Saturday Tony Quote Link to comment Share on other sites More sharing options...
