Jord Posted August 26, 2009 Share Posted August 26, 2009 Does anyone know how these will fair on a standard-bodied Z? Same size front and rear? Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 26, 2009 Share Posted August 26, 2009 Does anyone know how these will fair on a standard-bodied Z? Same size front and rear? Lowered? Quote Link to comment Share on other sites More sharing options...
Stew Posted August 26, 2009 Share Posted August 26, 2009 11s on the front????? Rear would be ok I think (with arches rolled) not sure on the front. my350z might hold the answer Jord as some of those guys run wide wheels. Quote Link to comment Share on other sites More sharing options...
Jord Posted August 26, 2009 Author Share Posted August 26, 2009 Stock suspension unfortunately as its the missus' car and I'm not allowed to fit the HSDs I have access to to it Its the fronts that concerns me, I know the rears should work with those sizes. Whats the widest [width and offset wise] anyone is running on the front? Quote Link to comment Share on other sites More sharing options...
St3v50z Posted August 26, 2009 Share Posted August 26, 2009 18s with 11J?? What rim is that? You should be ok on stock suspension, but dont quote me on that! Quote Link to comment Share on other sites More sharing options...
Digsy Posted August 26, 2009 Share Posted August 26, 2009 I think the fronts will stick out of the arches and look silly. I was running a 245/35 on 9" front with a +18 offset IIRC and on standard suspension they were right at the edge of the arch. However, I suspect you may want to run a stretched tyre, in which case I have no idea. Quote Link to comment Share on other sites More sharing options...
Jord Posted August 28, 2009 Author Share Posted August 28, 2009 Its OK, I may have found a pair of 18x9.5+10 I can use on the front. 11J was never going to work up front from my measurements. The wheels are SSR Professor SP1. Quote Link to comment Share on other sites More sharing options...
