Can I fit 20" wheels to an 04 JDM? 5Zigen ZR +520
jay3032
Lookin at wheels and suspension, really liking these! 5Zigen ZR +520
Lookin for some advice on the lowering of the suspension and also the camber/spacers
Can I get 20" on the Z? if so do I need to alter the suspension and camber?
Thanks
20s fit without a problem as long as they are a sensible size.
If you get proper fitting wheels you won't need spacers.
If you lower it generally it's ok but sometimes camber goes out of alignment. You can get a camber bolt for the rear which helps but if not then more goodies are required. :thumbs:
Thanks
Not sure if you want 20" ZR 520+ or you were talking in general, however they don't make them in that size.... 18 or 19" only.
Best Regards,
Gaz
