speedy Posted August 20, 2009 Share Posted August 20, 2009 I had new front tyres fitted about 3 motnsh ago toyo T1-R.They were no problem up until about a month ago when i notice taking right hand corners was a lot noiser than taking left hand corners....do you guys have any ideas what this could be? Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 20, 2009 Share Posted August 20, 2009 possibly lost a wheel weight, might need rebalancing, or the camber might be out, just get the camber toe and wheel alignment and blanacing checked. alot of places won't charge for an alignment test unless you need it adjusting. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted August 20, 2009 Share Posted August 20, 2009 Sounds as if it could be a wheel bearing. Quote Link to comment Share on other sites More sharing options...
GIXXERUK Posted August 20, 2009 Share Posted August 20, 2009 I'm with trev, sounds like the left hand front wheel bearing to me Quote Link to comment Share on other sites More sharing options...
speedy Posted August 24, 2009 Author Share Posted August 24, 2009 Thanks, but why would that only happen when turning right? and the noise only seems to come from the right. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 24, 2009 Share Posted August 24, 2009 because your putting that bearing under increased load with the lateral force of turning in that direction. good test for a wheel bearing is when parked get hold of the top of the tyre and give the wheel a good shake if you can feel movement backwards and forwards then the wheel bearing is on its way out. Quote Link to comment Share on other sites More sharing options...
speedy Posted August 25, 2009 Author Share Posted August 25, 2009 I tried that but i didnt feel to much movement. I am starting to think the bearing has gone...i am wondering if the torlerances are so tight that even the smallest amount would mean it on its way out....Any ideas on the cost of a new one or are the adjustable? Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted August 25, 2009 Share Posted August 25, 2009 Try repeating the procedure with the car jacked up and the wheel off the ground. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 25, 2009 Share Posted August 25, 2009 What trev said. It's a heavy car so jacking it up will give you a more accurate feel of he wheel without the weight pushing it into the ground. Quote Link to comment Share on other sites More sharing options...
speedy Posted August 25, 2009 Author Share Posted August 25, 2009 ok, so a small update!! The noise is a rumble, this actaully happens while going straight but get worse turning right but completely go's when turning left. Do people believe that this is still the bearings? Quote Link to comment Share on other sites More sharing options...
lamby Posted August 25, 2009 Share Posted August 25, 2009 IMO no i don't think so if it was the bearing it would be more of a groan or whine than a rumble. i may be tempted to get the wheel rebalanced as you may have lost a weight. Quote Link to comment Share on other sites More sharing options...
speedy Posted August 25, 2009 Author Share Posted August 25, 2009 Thanks, if it were a balance issue i would have thought it cause a vibration rather than a rumble? Quote Link to comment Share on other sites More sharing options...
lamby Posted August 25, 2009 Share Posted August 25, 2009 Maybe i would try jacking up if you havent already and see f that sheds any light on the situation if not im not sure Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 25, 2009 Share Posted August 25, 2009 whats the tyre wear like on the wheel, is it even or is it more worn to one side. might be need adjustment. also check the tyre for any blisters or bulbous sections, especially on theinside of the tyre wall where you cant see. Quote Link to comment Share on other sites More sharing options...
speedy Posted August 26, 2009 Author Share Posted August 26, 2009 The tyre wear is good, no feathering at all. I stopped off at the place that fits my tyres (has done foe years) and they couldn't see anything wrong with them at all. Might jack up the front over the weekend and have a look!! Its also going into TMG for a P1 so i'll ask them to have a look as well. Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted August 26, 2009 Share Posted August 26, 2009 I'm out of ideas nearly. I vaguly remember someone else having a noise issue and it was so ethong to do with there susspension, but that was more a knocking noise. Without being in the car it's very hard to diagnose anything. When you go back tomorrow it might be worth taking one of the fitters for a drive and see if he can hear it. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted August 26, 2009 Share Posted August 26, 2009 Try swopping your front wheels over and see in the noise stays the same or transfers to the other side. That will then eliminate that wheel and tyre. Quote Link to comment Share on other sites More sharing options...
