Lincolnbaggie Posted August 20, 2009 Share Posted August 20, 2009 Had a search and couldn't find anything, so can someone tell me how easy it is to remove the timing cover? Are there any special precautions to take, or is it simply a case of unbolting the bolts and removing and reverse to fit again? Are there gaskets that will need replacing or risk of losing any fluids etc. I've had a look at the CD workshop manual and it seems to be a nighmare job but don't know anything about it. Cheers for any advice. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted August 20, 2009 Share Posted August 20, 2009 you go first and then let us know what it was like!! You do need some type of sikoflex type of stuff when you reseal I think and there is the posibility of oil loss! You polishing the timing cover? Easier to do with a dremel, sand paper etc with the rad off perhaps? PM one of the guys on my350z as they have experience over there. And I know Alex has some spares, so he probably knows what the removal etc is all about! Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted August 20, 2009 Author Share Posted August 20, 2009 you go first and then let us know what it was like!! You do need some type of sikoflex type of stuff when you reseal I think and there is the posibility of oil loss! You polishing the timing cover? Easier to do with a dremel, sand paper etc with the rad off perhaps? PM one of the guys on my350z as they have experience over there. And I know Alex has some spares, so he probably knows what the removal etc is all about! I was thinking of something more than just a polish and for that it really needs to come off...... Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 20, 2009 Share Posted August 20, 2009 Had a search and couldn't find anything, so can someone tell me how easy it is to remove the timing cover? Are there any special precautions to take, or is it simply a case of unbolting the bolts and removing and reverse to fit again? Are there gaskets that will need replacing or risk of losing any fluids etc. I've had a look at the CD workshop manual and it seems to be a nighmare job but don't know anything about it. Cheers for any advice. Can not be removed and refitted successfully with engine in place. Quote Link to comment Share on other sites More sharing options...
Lincolnbaggie Posted August 20, 2009 Author Share Posted August 20, 2009 Had a search and couldn't find anything, so can someone tell me how easy it is to remove the timing cover? Are there any special precautions to take, or is it simply a case of unbolting the bolts and removing and reverse to fit again? Are there gaskets that will need replacing or risk of losing any fluids etc. I've had a look at the CD workshop manual and it seems to be a nighmare job but don't know anything about it. Cheers for any advice. Can not be removed and refitted successfully with engine in place. Cheers Alex, I knew you'd be the man who knew I'll have to rethink my plans then Quote Link to comment Share on other sites More sharing options...
Darren-B Posted August 20, 2009 Share Posted August 20, 2009 Had a search and couldn't find anything, so can someone tell me how easy it is to remove the timing cover? Are there any special precautions to take, or is it simply a case of unbolting the bolts and removing and reverse to fit again? Are there gaskets that will need replacing or risk of losing any fluids etc. I've had a look at the CD workshop manual and it seems to be a nighmare job but don't know anything about it. Cheers for any advice. Can not be removed and refitted successfully with engine in place. Cheers Alex, I knew you'd be the man who knew I'll have to rethink my plans then Take the engine out Quote Link to comment Share on other sites More sharing options...
