alanbolland Posted August 19, 2009 Share Posted August 19, 2009 Hi All. New to the 350z and site. but my engine temp is not in red but about three quartes of the way up. can anyone tell me what can cause this. Cheers guys Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted August 19, 2009 Share Posted August 19, 2009 Maybe you have not enough coolant in the tank? Engine leaking water/coolant? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 19, 2009 Share Posted August 19, 2009 checked you water level when cold faulty thermostat Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted August 19, 2009 Share Posted August 19, 2009 Also where does it start? at the very bottom and off the gauge or on the gauge at the bottom? They have been known to stick... Also does it continue to climb? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 19, 2009 Share Posted August 19, 2009 Air in the system? Leak somewhere? Thermostat may be shot. Temp sender may be shot, but usually this just means you get no reading. Afraid we are going to need more details. As Mark says, where does the needle start, and how long does it take to get to "hot". Does it go up and down noticably if you go for a spirited drive and then cruise for a while? Quote Link to comment Share on other sites More sharing options...
IanS16 Posted August 19, 2009 Share Posted August 19, 2009 Is 3/4 really that bad? I know mine is usually over half way on the gauge Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted August 19, 2009 Share Posted August 19, 2009 Doe the Fan even cut in?? More info!! Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 19, 2009 Share Posted August 19, 2009 Welcome to the forum, oh hot one Got some things to check and answer from the posts above - but if my temp needle creeps up over half way it will kick the fan in. If your guage is reading correct I would expect the fan to be going all the time - if it isn't then I would suspect the guage is giving a false reading Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 19, 2009 Share Posted August 19, 2009 Welcome to the forum, oh hot one Got some things to check and answer from the posts above - but if my temp needle creeps up over half way it will kick the fan in. If your guage is reading correct I would expect the fan to be going all the time - if it isn't then I would suspect the guage is giving a false reading Or the thermostat is cacked and not making it kick in Quote Link to comment Share on other sites More sharing options...
