greasemonkey1234 Posted August 18, 2009 Share Posted August 18, 2009 Hi Guys, Picked up my Zed a few weeks ago from a private buyer who had the car and was active on here. I test drove the car and there was no sign of the drag or axle click. It seems to only occur at low speed 20 - 30mph. When I turn left at low speed there is the sound of dragging a brick along tarmac coming from the passenger rear. After reading this forum it seemed like the axle click, however when I lightly apply the brakes there is a slight ssssshh-ssssshhhh-sssshhhh noise at speeds of around 60mph to rest. The noise gets louder the harder I apply the brakes. The problem seemed to occur overnight so was wondering if I had brake or axle problems?? Hopefully I can tap into some of your wisdom Quote Link to comment Share on other sites More sharing options...
Ebized Posted August 18, 2009 Share Posted August 18, 2009 First thing I would do is check the pads - I'm sure I've read that the inner (less obvious) ones wear quicker than those you can more easily see from the sides of the car. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 18, 2009 Share Posted August 18, 2009 As Colin has said get the wheels off and check the rear inner pads for wear Quote Link to comment Share on other sites More sharing options...
Stew Posted August 18, 2009 Share Posted August 18, 2009 I had this and it happened instantly. Basically one minute it was fine, the next it was noisy. New pads fixed it though. Quote Link to comment Share on other sites More sharing options...
Zednick666 Posted August 18, 2009 Share Posted August 18, 2009 Happened on my Golf, and could hear metal on metal clanging - turned out half the inner brake pad broke off and sat rattling round in the metal plate / dust guard. Quote Link to comment Share on other sites More sharing options...
greasemonkey1234 Posted August 18, 2009 Author Share Posted August 18, 2009 Thanks guys, Yeah I got home from work and the passenger rear brake was alot hotter than the others and quite smelly. I think that confirms the brake suspisions. New set of pads me thinks!! Quote Link to comment Share on other sites More sharing options...
