Lyger Posted August 12, 2009 Share Posted August 12, 2009 Anyone have a clue how to remove the A/T gear shroud? The bit with the D R P N + - written on it as the letters dont illuminate i think a bulbs gone. Quote Link to comment Share on other sites More sharing options...
marzman Posted August 12, 2009 Share Posted August 12, 2009 Yes mate, dead easy. See a guide i linked to in this diy: viewtopic.php?f=53&t=21147&hilit=paddle+shift&start=0 Quote Link to comment Share on other sites More sharing options...
marzman Posted August 12, 2009 Share Posted August 12, 2009 wait, wrong diy... i meant this one - direct link instead. http://liljerk.morpheus.net/350Z/dash_removal/ My tip is to use a very small flat headed screwdriver under the trim, at the part where it says to pull up with your hands... Quote Link to comment Share on other sites More sharing options...
Lyger Posted August 12, 2009 Author Share Posted August 12, 2009 Thanks but mines an Auto not a lot to grab. Ill try and post results. Thanks again. Quote Link to comment Share on other sites More sharing options...
marzman Posted August 12, 2009 Share Posted August 12, 2009 Mines an auto too. Its the same. Use a v.small flat head screwdriver under the plastic part, instead of grabbing it. I've dismantled mine about 15 times without any problem! Quote Link to comment Share on other sites More sharing options...
Lyger Posted August 12, 2009 Author Share Posted August 12, 2009 Whereabouts with the screwdriver??? Quote Link to comment Share on other sites More sharing options...
marzman Posted August 12, 2009 Share Posted August 12, 2009 On the guide where it says to put your fingers in and pull the shroud up - we cant get our fingers in there cos of the auto thing. so wedge the screwdriver under this part at the front from where the handbrake is and then twist the driver to force the shroud up. Once this is off, you'll have the dark grey auto thing... this is a b!tch to get off but be patient - there are 4 tabs around the outside of it, which you'll need a large flat head screwdriver to lever off. Be careful though, do this slowly as you need to apply A LOT of pressure! Quote Link to comment Share on other sites More sharing options...
Lyger Posted August 12, 2009 Author Share Posted August 12, 2009 Thanks !! Ill Have another go!! Quote Link to comment Share on other sites More sharing options...
Lyger Posted August 13, 2009 Author Share Posted August 13, 2009 Removed Cover to find No illumination for the + - Side of the Shroud. So only the letters illuminate! Quote Link to comment Share on other sites More sharing options...
