Liam's Z Posted July 5, 2006 Share Posted July 5, 2006 Is it me or is it wrong??? Quote Link to comment Share on other sites More sharing options...
hanel Posted July 6, 2006 Share Posted July 6, 2006 I'm not sure if it is wrong or not, can never figure out this daylight saving lark and if we are one hour ahead or one hour behind normal GMT or if summer or winter is daylight saving time. An easy way to fix it is to go into " Edit your Profile" and change the "Timezone" to 'GMT + 1 hour'. This will give you the right time on all the posts. Quote Link to comment Share on other sites More sharing options...
Chesterfield Posted July 6, 2006 Share Posted July 6, 2006 Hi - its not wrong, it is simply a restriction of software created in a land where daylight saving is not observed. It can be set to the correct time en masse, but then that would alter it considerably for our non-uk visitors/members. So for now, hanel is right, you will need to change it in your profile. Quote Link to comment Share on other sites More sharing options...
Liam's Z Posted July 6, 2006 Author Share Posted July 6, 2006 Hi - its not wrong, it is simply a restriction of software created in a land where daylight saving is not observed. It can be set to the correct time en masse, but then that would alter it considerably for our non-uk visitors/members. So for now, hanel is right, you will need to change it in your profile. Np,,, thanks hanel Quote Link to comment Share on other sites More sharing options...
hanel Posted July 6, 2006 Share Posted July 6, 2006 Thank you very much (said in an Elvis style) Quote Link to comment Share on other sites More sharing options...
