webber Posted August 11, 2009 Share Posted August 11, 2009 Hi all, I'm looking at buying the Eibach pro 30mm all round lowering springs, and I'm currently running a set of Rays on 20mm spacers all around. I'm just wondering if I'll need a camber adjustmet kit as well? And if so will I need front and back kits given that I'm not lowering it by much? And also I've noticed that Eibach do a camber toe bolt kit which is only cheap, is that likely to provide sufficient adjustment on its own? I imagine a few people on here will have had a similar set up so any advice will be greatfully received Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 11, 2009 Share Posted August 11, 2009 30 mm is quite a drop so you will require the top wishbone kit to get the camber back into line on the front You should get away with the toe and camber bolt kits on the rear. Quote Link to comment Share on other sites More sharing options...
Dblock Posted August 12, 2009 Share Posted August 12, 2009 30 mm is quite a drop so you will require the top wishbone kit to get the camber back into line on the front You should get away with the toe and camber bolt kits on the rear. I am also considoring this. Alex do you suplly top wishbone kits and toe and camber bolt kits? If not where could I get them from. Thanks Quote Link to comment Share on other sites More sharing options...
Dblock Posted August 12, 2009 Share Posted August 12, 2009 also my old car was lowered by 40mm by shocks and springs and it only needed 4wheel alignment why is the 350z different is it just akward or something else Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted August 12, 2009 Share Posted August 12, 2009 30 mm is quite a drop so you will require the top wishbone kit to get the camber back into line on the front You should get away with the toe and camber bolt kits on the rear. I am also considoring this. Alex do you suplly top wishbone kits and toe and camber bolt kits? If not where could I get them from. Thanks Your best bet for the above is one of the Traders on here. Start with CS or Envy but there are others. The answer to your other question is that the stock zed does not have a facility to adjust the camber on the front, so adjustable ball joints must be fitted to allow adjusting the camber back to oem settings. Toe is not an issue on the front. On the rear there is limited adjustment for the camber with the oem snail cams, so larger bolts are fitted to help solve this issue. If the new camber and toe bolts do not do the trick then adjustable arms will have to be fitted. Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted August 12, 2009 Share Posted August 12, 2009 Thanks Alex, I have the parts above available.... Quote Link to comment Share on other sites More sharing options...
webber Posted August 12, 2009 Author Share Posted August 12, 2009 Some really useful info there, thanks all I'll get saving for the necessary camber kits, don't fancy premature tyre wear really! Quote Link to comment Share on other sites More sharing options...
Dblock Posted August 12, 2009 Share Posted August 12, 2009 Thanks Alex, I have the parts above available.... Could you pm me the prices please thanks Quote Link to comment Share on other sites More sharing options...
Coby Posted September 17, 2009 Share Posted September 17, 2009 Hey, New here and don't have a 350 yet but just trying to plan ahead.... Are there Sportlines and Prolines available for the 350?? Which is preffered for the Zed?? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 17, 2009 Share Posted September 17, 2009 Hey, New here and don't have a 350 yet but just trying to plan ahead.... Are there Sportlines and Prolines available for the 350?? Which is preffered for the Zed?? Yes, both available. Stick with Proline. Quote Link to comment Share on other sites More sharing options...
Stew Posted September 17, 2009 Share Posted September 17, 2009 tried the sport kit but I have no complaints about the pro kit at all. Quote Link to comment Share on other sites More sharing options...
Coby Posted September 18, 2009 Share Posted September 18, 2009 OK Cheers, Is there a difference on lowering as in general Sport's are lower then Pro's aren't they?? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 18, 2009 Share Posted September 18, 2009 Yes. Quote Link to comment Share on other sites More sharing options...
Coby Posted September 20, 2009 Share Posted September 20, 2009 Whats the drop like with Both Kits... Pic comparison would be great. Quote Link to comment Share on other sites More sharing options...
Adriank Posted September 22, 2009 Share Posted September 22, 2009 I have pro kit on mine, its low, i have 19's and still scrape on bumps/ramps. Sport kit not needed, would be too low for std dampers IMO. If you want lower than pro kit, buy some coilovers. You WILL need rear camber arms, whichever you choose. Quote Link to comment Share on other sites More sharing options...
sketch Posted October 10, 2009 Share Posted October 10, 2009 whats the cheapest anyone has found for a set of eibach springs to lower the car about 30mm? i really want some now but have found the prices varies alot, cheers guys Quote Link to comment Share on other sites More sharing options...
Adriank Posted October 11, 2009 Share Posted October 11, 2009 My second hand ones will be available soon, £100 + delivery. Quote Link to comment Share on other sites More sharing options...
webber Posted October 12, 2009 Author Share Posted October 12, 2009 Adrian - PM'd you about springs. I'd like first dibs if possible Quote Link to comment Share on other sites More sharing options...
Adriank Posted October 12, 2009 Share Posted October 12, 2009 Will do mate, i'll let you know when they are off and ready to go. Quote Link to comment Share on other sites More sharing options...
webber Posted October 12, 2009 Author Share Posted October 12, 2009 Ok sounds good to me, thanks Quote Link to comment Share on other sites More sharing options...
ReaperRSX Posted October 13, 2009 Share Posted October 13, 2009 Adrian you have PM Quote Link to comment Share on other sites More sharing options...
rawbhp Posted October 13, 2009 Share Posted October 13, 2009 My second hand ones will be available soon, £100 + delivery. I PM'd you too. Pretty much straight after your post I think! I'll have to make sure I post as well next time... Quote Link to comment Share on other sites More sharing options...
Adriank Posted October 14, 2009 Share Posted October 14, 2009 I know you did mate, i have a few of you now in a list of pm recieved times, as soon as they are off ill be contacting with pics, as par interest recieved times. Quote Link to comment Share on other sites More sharing options...
webber Posted October 14, 2009 Author Share Posted October 14, 2009 Adrian - who is first in the queue then out of interest? I think I PM'd you straight away too Every second counts ey Quote Link to comment Share on other sites More sharing options...
Adriank Posted October 14, 2009 Share Posted October 14, 2009 You are mate, rawbhp was, but he is getting teins now. Quote Link to comment Share on other sites More sharing options...
