Gibby Posted August 6, 2009 Share Posted August 6, 2009 hey turns out the wife was driving the z and she said the oil light flashed, didnt believe her then it hapned while I was driving then when checked the oil there was none left???? Wots this all about? does this happen alot? or is there somthing else goin on? Any guidence would be most helpfull! Quote Link to comment Share on other sites More sharing options...
Carbon Coops Posted August 6, 2009 Share Posted August 6, 2009 just keep an eye on it and check it weekly to see if it loses any! when was it last serviced? coops Quote Link to comment Share on other sites More sharing options...
Husky Posted August 6, 2009 Share Posted August 6, 2009 none left Answer: add oil just check it more often and top up when neccesary, there could be a whole host of reasons it would chew oil at a faster rate i suppose. get it checked out if your worried. Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted August 6, 2009 Share Posted August 6, 2009 No oil left? WTF?? Thats shocking to hear, normally if theres no oil, its bye, bye engine...hello expensive replacement or re-build Jerry Quote Link to comment Share on other sites More sharing options...
IanS16 Posted August 6, 2009 Share Posted August 6, 2009 Could you have an oil drinking uprev (05-06 is it??) engine? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 6, 2009 Share Posted August 6, 2009 I hope you checked the oil level after the light did come on (while cold and on level ground). This light indicates when on tells you that you have no oil pressure and your basically pumping air. Very damaging for the engine. It is no way to be confused with a oil level indicator. That is your dipstick. Quote Link to comment Share on other sites More sharing options...
Stew Posted August 6, 2009 Share Posted August 6, 2009 oil light = very bad for VQ for the reasons Mike mentioned above. Quote Link to comment Share on other sites More sharing options...
Gibby Posted August 7, 2009 Author Share Posted August 7, 2009 yeah its a 55plate and it was last serviced in may. its been fine the past couple of days tho will check weekly and put in to get checked out just to make sure nothings wrong.Ive been giving her sum wellie since ive had her and havent checked th oil so im guessin thats all. Just wanted to know if there was any problem areas with the z. Thanks guys Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 7, 2009 Share Posted August 7, 2009 did you check the oil after the service. A member just a coupl eof weeks ago was driving around with no oil just after a service. Looks like the dealers forgot to put the oil in. Quote Link to comment Share on other sites More sharing options...
Husky Posted August 7, 2009 Share Posted August 7, 2009 did you check the oil after the service. A member just a coupl eof weeks ago was driving around with no oil just after a service. Looks like the dealers forgot to put the oil in. Thats nuts!!!!!! Quote Link to comment Share on other sites More sharing options...
R35LEE Posted August 7, 2009 Share Posted August 7, 2009 Gibby, this is not good at all and will have taken years off the life of your engine, thats if it's not already destroyed. put oil in and take it to get looked at Quote Link to comment Share on other sites More sharing options...
Gibby Posted August 7, 2009 Author Share Posted August 7, 2009 i didnt check after it got serviced as it got done at dealer b4 i bought it! ive put oil in it! 2ltr and its been fine but i will def get it checked out. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted August 7, 2009 Share Posted August 7, 2009 i didnt check after it got serviced as it got done at dealer b4 i bought it! ive put oil in it! 2ltr and its been fine but i will def get it checked out. you've put 2lts of oil in. Thats excessive use or never had enough put in in the first place. The Z takes 4.7ltrs of oil when doing a oil and filter change. To top up you should never need more than 1ltr i think Quote Link to comment Share on other sites More sharing options...
Darren-B Posted August 7, 2009 Share Posted August 7, 2009 Mental note, dont buy a car off gibby Quote Link to comment Share on other sites More sharing options...
bronzee Posted August 8, 2009 Share Posted August 8, 2009 did you check the oil after the service. A member just a coupl eof weeks ago was driving around with no oil just after a service. Looks like the dealers forgot to put the oil in. Thats nuts!!!!!! Unfortunately it's not usual. It's happened to two of my friends, both after a Nissan dealer service. Had this happen with my own car with coolant, told them it was low, went to leave and they hadn't filled, but had charged me for it. Furious. As it's already been asked if it's a rev-up engine some of them have had a tendency to burn excessive oil. Very well documented on www.my350z.com. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted August 8, 2009 Share Posted August 8, 2009 i didnt check after it got serviced as it got done at dealer b4 i bought it! ive put oil in it! 2ltr and its been fine but i will def get it checked out. you've put 2lts of oil in. Thats excessive use or never had enough put in in the first place. The Z takes 4.7ltrs of oil when doing a oil and filter change. To top up you should never need more than 1ltr i think +1 1ltr per 1000 miles is the accepted max use I think something like that. 2ltrs straight off the bat is madness! Quote Link to comment Share on other sites More sharing options...
