what is it?
stichy
for some strange reason i feel like there should be some red dwarf, "yes but what is it?" type of quote happening here...
if it makes you feel better,
what does it do????
is it normal to just fit an uprated front arb, and not a rear as well?
usually people fit both, i have the eibach adjustable kit on mine, which is red instead of blue, if you get a chance jack the car up and see if there are more than one bolt hole for you to use, also check the rear to see if you have a very odd shaped blue bar going across the back :)
