Front Nissan Badge taken off
Bluffy
Took the front nissan badge off and replaced it with the Z badge from Funkystyling.
It was fairly easy to get the badge itself off, but the glue itself... my god what a pain in the @ss.
Shall put a pic on 2mora after its nice a clean.
Not sure if i am going to bother with the rear one. What is behind the rear Nissan Badge? are there any holes or is it just smooth paintwork?
Yeah definitely two little holes on the rear for the coupe......
I found that the rear was slightly easier due to not being recessed. Quick tip.... once you get down the end of the glue residue. Then use a good quality pencil eraser to just rub off the residue...... works a charm! :thumbs:
With the front badge being in a recess, it was extremely easy to fit, no worries of not getting it straight. However not got this on the back, so slightly worried of fking it up and ending up with the badge not in the centre/not straight.
Well you can definitely work out that its in the middle from the holes etc.... you should be ok. You only have to worry about putting it on straight. Just lock your hands ;)
Just stick a little bit of masking tape at along the straight bits of the nissan burger, then when you align the new one, it just needs to sit between the tape :)
Andy
