True dual Y-pipe
maz77
What are you trying to achieve?
If the exhaust is gonna be a custom job then just get them to fab a 2-2 piece for you
Thats what I'd do. Same diameter all the way then :thumbs:
I wouldn't even bother the y piece tbh. I'd just run 2 pipes from the cats B)
I thought there was something to be had from the cross flow of combining both sides. Cant remember where I read it mind :blush:
that would delete the flexi's making it more prone to cracks
Not really. APS & Invidia both use that design.
Any decent custom exhaust place would be able to do it :)
to put things into prespective guys.
the idea was to utilise the end pipes of the K1 exhaust.
plan:
change y-pipe.
get custom made twin middle pipe.
I wasn't planning on getting a full custom exhaust.
in the picture below you will see the single middle pipe the K1 uses.
it looked easy enough for me (apart from clearing the diff issues) to change that to 2 parallel pipe. add to it a 2 to 2 y-pipe and I would have a true dual
the question is, would that loose me some top end torque in NA form or not?
