a2orry Posted January 13, 2015 Share Posted January 13, 2015 (edited) Probably that white heatproof mat that they put between the exhaust and the tin shield.edit cats and original nissan Y pipe have this. Edited January 13, 2015 by a2orry Quote Link to comment Share on other sites More sharing options...
keithvmx1200 Posted January 14, 2015 Share Posted January 14, 2015 I had a bitter like burnt coffee smell when I put my foot down hard but had floppy clutch pedal to go with it but then would go back to normal. Regards Keith Quote Link to comment Share on other sites More sharing options...
jimboy2 Posted January 14, 2015 Share Posted January 14, 2015 I have this exact same issue. Doesn't leak any fluid so not really worried any more. Only happens when I give it a little welly Quote Link to comment Share on other sites More sharing options...
DarmoZ Posted September 14, 2016 Share Posted September 14, 2016 (edited) I used to get the distinct clutch smell (it would linger even after the car has pulled up and you could smell it when you step out) then one day the clutch went and it got replaced. However the smell under hard acceleration past 4k rpm still remained. It's a different type of smell to the clutch one i had before (clutch smell is much more potent) Like others it's only really noticeable with windows down, and goes away after a few seconds of letting off the pedal. Since i can disregard the clutch being new, i put it down to cat's / exhaust like others have. Edit: I also disregard belts because they have been changed recently too. Edited September 14, 2016 by DarmoZ Quote Link to comment Share on other sites More sharing options...
Rippo350z Posted September 30, 2016 Share Posted September 30, 2016 I also second this opinion of Exhaust/Cat buildup. I have experienced this during warm conditions and booting it. I now have a new full cobra exhaust system with cobra CATS and an uprev and haven't had this issue since but i expect it to come back one day. I believe it to be a build up from inner city driving (my Work commute is 6 miles tops) then opening her up. Since I've had the upgrades though she gets opened up all the time (OMG the sound). either that or my clutch will go at some point, either way don't worry 1 Quote Link to comment Share on other sites More sharing options...
ThreeFiddyZ Posted September 30, 2016 Share Posted September 30, 2016 I get this with mine when I drive in a spirited manner, the exhaust gets hot and smells and the sides of the transmission tunnel inside the car get hot, I've put mine down to the cats or exhaust parts. Sent from my Xperia Z2 using Tapatalk Quote Link to comment Share on other sites More sharing options...
DarmoZ Posted January 31, 2017 Share Posted January 31, 2017 I also second this opinion of Exhaust/Cat buildup. I have experienced this during warm conditions and booting it. I now have a new full cobra exhaust system with cobra CATS and an uprev and haven't had this issue since but i expect it to come back one day. I believe it to be a build up from inner city driving (my Work commute is 6 miles tops) then opening her up. Since I've had the upgrades though she gets opened up all the time (OMG the sound). either that or my clutch will go at some point, either way don't worry Interesting, my OEM cats will get replaced with brand new Berks soon, followed by uprev, hopefully the smell will go after as it has done on yours. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rock_Steady Posted January 31, 2017 Share Posted January 31, 2017 Bit of a long shot but, if you have leak down the side of the head or block then run the car till its super hot it'll make a smell in the cabin. Or if you have spilt oil whilst putting it in, that'll make a smell when hot too. Quote Link to comment Share on other sites More sharing options...
TT350 Posted January 31, 2017 Share Posted January 31, 2017 Wallet. Quote Link to comment Share on other sites More sharing options...
Jay Kay Posted January 31, 2017 Share Posted January 31, 2017 Mine did the same. Usually didn't drive very fast but on the odd occasion I booted it I could sometime smell a faint smell, almost chemical like. mine was an HR with 18k miles on the clock. Quote Link to comment Share on other sites More sharing options...
MIGWEL Posted January 31, 2017 Share Posted January 31, 2017 Mine does it too. HR model with 13'000 miles No smell at normal driving but when giving it a bit of a heavy foot then the smell appears. Not a clutch smell but a burnt chemical sort of odour then it soon clears Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted February 1, 2017 Share Posted February 1, 2017 Mine does this too. I've had a new clutch etc. Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted February 1, 2017 Share Posted February 1, 2017 I remember reading somewhere the rocker covers could be the cause when the gaskets are on the way out ? Quote Link to comment Share on other sites More sharing options...
Rook Posted February 2, 2017 Share Posted February 2, 2017 It's the cats burning of crap, most performance cars do it, you just can't usually smell it. If you find it smells a bit musty or chemical-like as some put it - even if the car's already warm - the first time you absolute bury it for a sustained period, but each time you do it after that it's less or gone, it's almost certainly that and nothing to worry about. Quote Link to comment Share on other sites More sharing options...
Jp606 Posted February 3, 2017 Share Posted February 3, 2017 They all do this. Quote Link to comment Share on other sites More sharing options...
