ikarus Posted July 25, 2009 Share Posted July 25, 2009 Hey, I'm still getting used to my newly purchased 03 fairlady . I've noticed sometimes, but not always, a high pitched noise coming from th rear of the car inside. I can hear it also without the engine running (ignition on). Its loud enough that i can also here it while driving. Anyone got any idea if this is normal, and if not where to even start looking? Many thanks, Dave Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 25, 2009 Share Posted July 25, 2009 Fuel Pump. Quote Link to comment Share on other sites More sharing options...
ikarus Posted July 25, 2009 Author Share Posted July 25, 2009 Fuel Pump. Thanks ZMANALEX , is this normal or should i be seeking replacement? Dave Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 25, 2009 Share Posted July 25, 2009 Fuel Pump. Thanks ZMANALEX , is this normal or should i be seeking replacement? Dave Fill the tank up and see if the noise changes. The pump should be farly quiet and is not a cheap item to replace. What mileage have you done? if it is high, then perhaps removing the pump and cleaning the small panel filter may help. The pump is in the tank directly behind the driver's seat and is reached by removing the rear interior trim etc. Alex. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted July 25, 2009 Share Posted July 25, 2009 Dave, PM sent mate Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted July 25, 2009 Share Posted July 25, 2009 Dave, If it turns out to be the fuel pump and you don't fancy paying new prices then give me a shout as I have 2 available. One is a stock pump which has done only 9000 miles, comes complete with seals, screws and float etc. The other is a Nismo uprated fuel pump which has covered 1500 miles. I require, £50.00 for the stock pump and £100.00 for the Nismo. Let me know if I can help you further. Cheers, Alex. Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 25, 2009 Share Posted July 25, 2009 Tonneau cover helps to quieten the fuel pump sound Quote Link to comment Share on other sites More sharing options...
