Dblock Posted July 22, 2009 Share Posted July 22, 2009 I was wondering when should the auto box oil be changed? What type of oil should it be replaced with and how much? The other thing is most 350z dont need the lsd but does the auto have lsd and is the diff vicous no maintenace or something? Also my car is coming up for a p3 so do the spark plugs need changed as 9kmiles seem a bit quick to change plugs? Quote Link to comment Share on other sites More sharing options...
sunset350z Posted July 22, 2009 Share Posted July 22, 2009 If your car has only done 9k i wouldn't worry about gearbox oil and spark plugs, that's a long way off. All 350z's have lsd's and no maintenance required. Saying that its good practice to change the box and diff oils at about 50k but not necessary Quote Link to comment Share on other sites More sharing options...
Dblock Posted July 23, 2009 Author Share Posted July 23, 2009 If your car has only done 9k i wouldn't worry about gearbox oil and spark plugs, that's a long way off. All 350z's have lsd's and no maintenance required. Saying that its good practice to change the box and diff oils at about 50k but not necessary my car has done nearly 60k but at the last service the plugs where changed so do they need done again? Also what type of oil does the auto box take and how much? same with the diff? Thanks Quote Link to comment Share on other sites More sharing options...
sunset350z Posted July 23, 2009 Share Posted July 23, 2009 The spark plugs should last another 50k, the oil for the autobox i'm not sure about, someone with an auto will let you know, but the diff takes Castrol Syntax 70/90 gear oil Quote Link to comment Share on other sites More sharing options...
Zazur Posted July 23, 2009 Share Posted July 23, 2009 The autobox oil you will need is AT-Matic J Fluid, Nissan part no. KE908-99932, usually no Nissan dealers stock it so you will have to order it Quote Link to comment Share on other sites More sharing options...
Dblock Posted July 24, 2009 Author Share Posted July 24, 2009 The autobox oil you will need is AT-Matic J Fluid, Nissan part no. KE908-99932, usually no Nissan dealers stock it so you will have to order it do you know the grade of it as i would rather put other stuff in. Cheers Quote Link to comment Share on other sites More sharing options...
Zazur Posted July 29, 2009 Share Posted July 29, 2009 No don't know the grade of the oil. Be very carefull about using something else Quote Link to comment Share on other sites More sharing options...
sunset350z Posted July 30, 2009 Share Posted July 30, 2009 I'm sure Nissan use castrol oil for the autobox. Quote Link to comment Share on other sites More sharing options...
sunset350z Posted July 30, 2009 Share Posted July 30, 2009 I don't think it has a grade, it's just known as J MATIC FLUID. Royal purple oils sell the reccomended oil for your Auto but it may be slightly more expensive. Quote Link to comment Share on other sites More sharing options...
Dblock Posted July 31, 2009 Author Share Posted July 31, 2009 I don't think it has a grade, it's just known as J MATIC FLUID. Royal purple oils sell the reccomended oil for your Auto but it may be slightly more expensive. I might just get some from nissan then. I ordered some diff oil though and silkolene. Quote Link to comment Share on other sites More sharing options...
