Digsy Posted November 3, 2006 Share Posted November 3, 2006 For N/A it all seems like a lot of effort for little gain. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted November 3, 2006 Share Posted November 3, 2006 For N/A it all seems like a lot of effort for little gain. That may be true - but a parallel EMS is the ONLY way you will extract ANY top-end gains with this car. Mid-range, plenum, yes due to more optimal fuel/air mix flow, but in general NO. To be fair, the UTEC is more squarely aimed at FI options in terms of cost/benefit Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted November 3, 2006 Share Posted November 3, 2006 the OEM ECU has already got "3 maps". Limp mode, fuel saving and aggressive driving. How does it switch between those? Quote Link to comment Share on other sites More sharing options...
Baptist Posted November 3, 2006 Share Posted November 3, 2006 Depending on feedback from various sensors on the engine, it will change maps for example, if knock is detected, air temp changes etc. The UTEC takes over on closed loop running (WOT). One thing to note, is that the UTEC does completely take over from the standard ECU (i.e. the map programmed wont change like the factory unit, so you always have the same performance) the UTEC does have knock control, so if your running your 'aggressive' map and the knock sensors detect any knock then it will retard timing accordingly. Quote Link to comment Share on other sites More sharing options...
ir_fuel Posted November 3, 2006 Share Posted November 3, 2006 Curious to see the torque curve on a standard Z and a standard Z with this fitted Quote Link to comment Share on other sites More sharing options...
Baptist Posted November 3, 2006 Share Posted November 3, 2006 Wont be much different in shape, probably just a bit fatter in the mid range. Depending on what mods you have. I wouldnt expect massive gains, but it allows you to set the car up properly. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted November 4, 2006 Share Posted November 4, 2006 Depending on feedback from various sensors on the engine, it will change maps for example, if knock is detected, air temp changes etc. The UTEC takes over on closed loop running (WOT). One thing to note, is that the UTEC does completely take over from the standard ECU (i.e. the map programmed wont change like the factory unit, so you always have the same performance) the UTEC does have knock control, so if your running your 'aggressive' map and the knock sensors detect any knock then it will retard timing accordingly. Bap, I don't think it changes maps on the fly does it? Maps are generally changed via a remote switch, or if not included (it being optional) at the unit itself I think what it does do, when it detects knock, is to reduce timing advance to remove knock and then progressively re-instate that timing advance to optimal just-before-knock value (all this is user controllable during set-up). The stock ECU certainly does switch from the normal map to a retarded map when knock is detected - which is a very gross adjustment by comparison since a lot of timing is pulled. The UTEC takes over in open loop running towards WOT - at less than say 40-50% WOT** the ECU is in closed loop using feedback from the O2 sensors to control the AFR ** This RPM value is specified via UTEC set-up parameters Quote Link to comment Share on other sites More sharing options...
