Who knows about SSL and self-signed certificates??
marzman
Hey,
Sorry - a work related question but im going mad here!
i need to communicate via SSL for a new piece of development, and have got the necessary java methods to handle a socket connection with SSL. I simply need to pass in the name of a keystore and its password.
To create the keystore im using a java tool called Keytool - but i cant figure out how to generate the appropriate certificates - which i want to be 'self-signed' (this is the important bit).
I need a Root Certificate, Personal Certificate, and Private Key... using Keytool i've got the Root Cert and the Private Key, but i cant generate the Personal Certificate, as this is usually issued by a CA such as verisign...!!
Nobody in my office has had to do this before so im on my own, and very stuck!!
Any suggestions anyone?
:bang::bang:
you need to contact a company like verisign who will sell you one and have it verified.
I work for the NHS and have found Verisign to be expensive.
Try instantssl.com and digicert.com
Cheers mate,
I need to make a self-signed certificate - i.e. not use a CA such as verisign. My SSL communications are going to be on a private network and therefore can be self signed - saving us mucho $$ :lol:
have you actually installed the root cert?
im having cert issues of another kind today with server2008 and MS unwillingness to support self signed certs! :rant:
I dont have a root certificate to install - i believe i have to generate my own...?
Im now officially bald as i've been tearing my hair out since 11am!
found this....
e223. Creating a New Key Pair and Self-Signed Certificate Using keytool
This example uses the keytool program to create a new key pair and self-signed certificate for the principal Duke. The example generates a 1024-bit Digital Signature Algorithm (DSA) key pair.
> keytool -genkey -alias alias -keystore .keystore
Enter keystore password: password
What is your first and last name?
[unknown]: Duke
What is the name of your organizational unit?
[unknown]: JavaSoft
What is the name of your organization?
[unknown]: Sun
What is the name of your City or Locality?
[unknown]: Cupertino
What is the name of your State or Province?
[unknown]: CA
What is the two-letter country code for this unit?
[unknown]: US
Is correct?
[no]: yes
To create a 1024-bit RSA key:
> keytool -genkey -keyalg RSA -keysize 1024 -alias alias -keystore .keystore
not sure re keytool, used openssl and other products to create a cert.
filezilla has a cert tool built in (FTP server software), maybe you could use that? I've used that and then XCA to convert the server cert for a client side cert and imported it and using FTPS successfully with certs now :) is this development using 'windows' certs in the certificate store?
