Window Wiring (Passenger Door)
SMR350Z
I have developed the window issues with both the windows on my Z. So today I set about the window rest to see if that would fix it.
http://www.350z-tech.com/zwiki/Service:TSB_04-089_Window_Regulator_Motor_Reset_Procedure
The first few steps were fine, then I swiftly moved onto my school boy error!
When attempting to unplug the electric window switch (just press the large tab with a flat driver) I actually managed to split the plug (by pressing in the wrong tabs, about 3 smaller tabs). No great damage except I'm not sure which wire goes in which whole on the plug, as it came completely apart. Can anyone help? Perhaps someone has a door panel off and can photograph the layout for me?
I've added some photos below to show exactly what I mean....
Here is the drivers side (RHS) - Just fine!
Here is the passenger side (LHS) after I did my magic! - Not so fine!
Can anyone supply a clear photo from this angle of the "passenger side electric window switch plug".
I need to ensure I get the right colour in the right slot.
My Z is a 2003 import, should that be of importance.
Many thanks
  • 3 years later...
did he ever get back to you? i just had this happen to me.
The last post was in 2009 so you might not get a reply, what is the issuie you have sure someone on here can help if its just the re-set you need look in the guides section if more post the problem you have
