BRO-T Posted July 8, 2009 Share Posted July 8, 2009 Does anybody know where it is located? Nissan currently want £300+vat to locate it and then probably more to troubleshoot a problem!!! Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted July 8, 2009 Share Posted July 8, 2009 ? Conversion to what? Quote Link to comment Share on other sites More sharing options...
BRO-T Posted July 8, 2009 Author Share Posted July 8, 2009 KM to MPH!! Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 8, 2009 Share Posted July 8, 2009 with the 3 small pods, you have to swap them for a UK version. I thought as part of the SVA test the main speedo should be done. Quote Link to comment Share on other sites More sharing options...
BRO-T Posted July 8, 2009 Author Share Posted July 8, 2009 Basically my car is at nissan because the instrument dials are playing up, fuel, temp, revs and speedo. Currently a replacement set is £1200+vat, but becuase its a JDM they need to make sure that the chip used to convert the reading from KM to MPH isn't whats causing the problems! This is goign to be another £300+vat just to investigate this further I just want to know to try and cut costs down, where is the conversion chip lcoated on the car, ECU, engine bay etc?? Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 8, 2009 Share Posted July 8, 2009 I don't know where its located or how its done. If you need replacement dials or pods though it will be worth your while contacting R35LEE on here. He has good access to 2nd hand parts. Or try ZMANALEX who can get nissan parts cheaper than the dealers. Quote Link to comment Share on other sites More sharing options...
BRO-T Posted July 8, 2009 Author Share Posted July 8, 2009 If you need replacement dials or pods though it will be worth your while contacting R35LEE on here. He has good access to 2nd hand parts. Or try ZMANALEX who can get nissan parts cheaper than the dealers. Thnaks for that, i've already pm'd them both. Just waiting for a reply. Quote Link to comment Share on other sites More sharing options...
BladesGrant Posted July 8, 2009 Share Posted July 8, 2009 I always thought it was something that was done behind the speedo and rev unit. Not 100% sure but think thats where the chip is located. There has to be something around there to change the rate at which the speedo goes up and to change the digital Kilometers to Miles. Don't quote me on that though!! I would just keep guessing your speed and fuel though at that price!! Hope you have sold your wheels, your going to need the money at this rate. Hope you get it sorted soon matey. Quote Link to comment Share on other sites More sharing options...
R35LEE Posted July 8, 2009 Share Posted July 8, 2009 Should either be on / inside the clocks or directly under the clocks in the wiring. I dont think thats your problem though as it only alters / converts the speed pulse. I could be wrong. If you want the UK Clocks off me I can supply them, but for them to work you need the find the conversion chip and remove it otherwise speedo wont register anything. Also plug in to diagnostics as these problems can be brought about from the meter amp or the BCM unit. Where abouts in the country are you?? Call me and I will save you a fortune Quote Link to comment Share on other sites More sharing options...
BRO-T Posted July 8, 2009 Author Share Posted July 8, 2009 R35Lee, already PM'd you today, i'll send you my number Its at Nissan and they're certain its the dials, i'm guessing they've run a diagnostics on it. If they're sayign its the clutser, how wrong could they be?? I'm in Birmingham m8, willing to travel to get this fixed!!! Quote Link to comment Share on other sites More sharing options...
R35LEE Posted July 8, 2009 Share Posted July 8, 2009 Hope to see you Saturday Andy! Best regards, Lee Quote Link to comment Share on other sites More sharing options...
premmitt Posted July 8, 2009 Share Posted July 8, 2009 Should either be on / inside the clocks or directly under the clocks in the wiring. I dont think thats your problem though as it only alters / converts the speed pulse. I could be wrong. If you want the UK Clocks off me I can supply them, but for them to work you need the find the conversion chip and remove it otherwise speedo wont register anything. Also plug in to diagnostics as these problems can be brought about from the meter amp or the BCM unit. Where abouts in the country are you?? Call me and I will save you a fortune Can you get UK centre console clocks too?? (the 3 pod above the satnav) Quote Link to comment Share on other sites More sharing options...
