lewis Posted July 1, 2009 Share Posted July 1, 2009 Does the 350z use a canbus system of any sort or is it a simple ECU system? What I want to know is if I take a engine and harness/ECU etc from a donor vehicle will I need all of the other modules from around the car to operate the engine? I know its a odd question but I want to build a engine on a rig and get it running. Cheers Quote Link to comment Share on other sites More sharing options...
Husky Posted July 1, 2009 Share Posted July 1, 2009 if it is (which im sure someone with more knowledge than me will tell you), i think you can take a module off as long as you replace it with the appropriate resistor as a terminator of the stub.. but im sure someone will be along shortly who knows more maybe 60ohms? Quote Link to comment Share on other sites More sharing options...
lewis Posted July 1, 2009 Author Share Posted July 1, 2009 Just been told Ill need the keys, NATS module and ECU from the same vehicle to make it work. Does any one know where you can buy off the shelf complete Engine harness/ECU kits to run the engines? Quote Link to comment Share on other sites More sharing options...
IanS16 Posted July 1, 2009 Share Posted July 1, 2009 Actually I'm pretty sure you can get the ECU to forget the previous car by using a NATS code. Nissan can reprogram the ECU by using a code on the ignition barrel. (second hand info BTW) PM ZMANALEX, he knows EVERYTHING!! Quote Link to comment Share on other sites More sharing options...
