ollyd Posted June 30, 2009 Share Posted June 30, 2009 I have just got a 2003 UK spec GT. Noticed I was getting no hi beam on investigating realised the lights have been upgraded to bi xenon but the high beam bulbs just glows rather than firing up properly. I suspect the previous owner may have simply connected the ballast from the single HID unit to the normal beam and not fitted a second ballast. Does anyone know if this sounds at all likely or is this possibly caused by something else? Any advise on the matter would be appreciated as currently have no hi beam I realise I will prob have to remove bumper to do any work on them. Quote Link to comment Share on other sites More sharing options...
P15UL T Posted June 30, 2009 Share Posted June 30, 2009 Hi there. I am unsure on how a bi Xenon kit would work on the older style lights. The newer style light have a tilting mechenism in them to allowthe high beam function to work but the older style didn't. So us there a space in the headlight where the high beam bulb should be ? Paul Quote Link to comment Share on other sites More sharing options...
M13KYF Posted July 1, 2009 Share Posted July 1, 2009 I thought the Bi Xenons were sold as a straight swap by courtesy parts Quote Link to comment Share on other sites More sharing options...
Chris`I Posted July 1, 2009 Share Posted July 1, 2009 Any pics of the unit? I'm a little confused as to wether you have the bi-xenon units or the older single xenon unit with 2 HID bulbs in? Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted July 1, 2009 Share Posted July 1, 2009 I have just got a 2003 UK spec GT. Noticed I was getting no hi beam on investigating realised the lights have been upgraded to bi xenon but the high beam bulbs just glows rather than firing up properly. I suspect the previous owner may have simply connected the ballast from the single HID unit to the normal beam and not fitted a second ballast. Does anyone know if this sounds at all likely or is this possibly caused by something else? Any advise on the matter would be appreciated as currently have no hi beam I realise I will prob have to remove bumper to do any work on them. Hi mate, i have been there i did this conversion and it works but is impractical as i will explain. i left the oem xenon unchanged but converted the H7 high beam light with a 6000k kit complete with ballast, xenon bulbs and loom and it was a straight forward conversion. However because you ususally flash on and off you headlight it never gets up to temp and hence the poor light. unless you put it on and drive, blinding everyone in your path it will be useless. Secondly the xenon bulbs longevity will be markedly reduced with this kind of usage. The only solution is to buy the 06+ bi-xenon light set which is not cheap. there is a single xenon bulb which has a shutter operated by a solenoid that allows or prevents more light through producing you dipped or high beam My solution was to get 7500K rated 80W H7 bulbs and replace oem ones and it looks like xenons and very bright. they are not for road use apparently As LED conversion of the parking lights completes the look Quote Link to comment Share on other sites More sharing options...
ollyd Posted October 31, 2009 Author Share Posted October 31, 2009 Discovered I had modified standard lights thanks for all the advice. Am converting to Bi-xenons now. Quote Link to comment Share on other sites More sharing options...
ollyd Posted November 1, 2009 Author Share Posted November 1, 2009 Ordered bi-xenons now anyone know what mods I will need to make? They come with all bulbs and ballast. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
350doc Posted November 1, 2009 Share Posted November 1, 2009 If they are MY07 Nissan Bi-Xenons, you just plug and play! Quote Link to comment Share on other sites More sharing options...
ollyd Posted November 5, 2009 Author Share Posted November 5, 2009 Exellent hopefully get them tomorrow will update. Quote Link to comment Share on other sites More sharing options...
P15UL T Posted November 5, 2009 Share Posted November 5, 2009 Exellent hopefully get them tomorrow will update. should be there Quote Link to comment Share on other sites More sharing options...
ollyd Posted November 7, 2009 Author Share Posted November 7, 2009 Yes they just plugged in thanks for advice. Quote Link to comment Share on other sites More sharing options...
