help with ecu fault PLEASE
addmanb
finally manged to get an error code on my 03 fairlady,
P1065 ECM Power Supply Heater
just wondered if anyone had had the same problem,. my ecu light comes on only if the car has previously been running, then swithched off and then the light will come on. once the car has cooled down. it then stays off untill i switch the car on and off again. has anyone run into anything similar. cheers
ADD
ADD
Try an ECU reset. :thumbs:
