shieldsie Posted June 29, 2009 Share Posted June 29, 2009 Hi all, the airbag light is constantly flashing!! I had this re-set with the computer which sorted it for 24 hours only!? On reading the car manual it talkes about servicing a small tseatbelt tension device has well has many other things. Can anyone advise or is it a NIssan task (ouch) Quote Link to comment Share on other sites More sharing options...
mic-39 Posted June 30, 2009 Share Posted June 30, 2009 Hi I had the same problem and it turned out to be the springy thing in behind the steering wheel that needed to be replaced. It was under warranty but i believe that reading the srs(airbag) codes may be specialist nissan dealer thing Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 30, 2009 Share Posted June 30, 2009 Check under the seats to make sure that the loom clips are all connected. You may have had a bottle or something roll around under the seat and cause a disconnect. It may be worth disconneting the battery and then unplugging and plugging in all the connectors.. And then trying the reset. Quote Link to comment Share on other sites More sharing options...
Renegade Posted June 30, 2009 Share Posted June 30, 2009 As said check the seat connections.It seems to be the passenger side that goes off. Then reset here. viewtopic.php?f=10&t=24151 Quote Link to comment Share on other sites More sharing options...
shieldsie Posted June 30, 2009 Author Share Posted June 30, 2009 I am soooooooooo happy!!!!!! Thanks to everyone. Worked first time of carrying out the re-set procedure. Cheers. Quote Link to comment Share on other sites More sharing options...
