Greekman Posted June 27, 2009 Share Posted June 27, 2009 After changing clutch and flywheel there was a rattle coming from the exhaust. The exhaust was remounted while pushed and flexed upwards and the rattle got better but its still there... ps its not the firanza flywheel...thats a different noise i can distinguish... the KW V1s where adjusted at the same time higher 1cm front and 0.9cm rear...but i swear the car is scraping the same if not a bit more now as i v got 3 speed bumps just outside my house driving many times a day... had a word with mechanics at the dealership and they advised me to ask whether there are any aftermarket rubber mountings smaller than the OEM for then to try and lift the exhaust higher..... Any suggestions??? Quote Link to comment Share on other sites More sharing options...
Greekman Posted June 27, 2009 Author Share Posted June 27, 2009 After changing clutch and flywheel there was a rattle coming from the exhaust. The exhaust was remounted while pushed and flexed upwards and the rattle got better but its still there... ps its not the firanza flywheel...thats a different noise i can distinguish... the KW V1s where adjusted at the same time higher 1cm front and 0.9cm rear...but i swear the car is scraping the same if not a bit more now as i v got 3 speed bumps just outside my house driving many times a day... had a word with mechanics at the dealership and they advised me to ask whether there are any aftermarket rubber mountings smaller than the OEM for then to try and lift the exhaust higher..... Any suggestions??? Quote Link to comment Share on other sites More sharing options...
scottsoulby Posted June 27, 2009 Share Posted June 27, 2009 I think there called powerflex exhaust mounts, you can buy them from your local halfords, they are stiffer and smaller so should do the trick Quote Link to comment Share on other sites More sharing options...
Greekman Posted June 27, 2009 Author Share Posted June 27, 2009 I think there called powerflex exhaust mounts, you can buy them from your local halfords, they are stiffer and smaller so should do the trick Off to have a look at halfrauds.... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 27, 2009 Share Posted June 27, 2009 Think they do "adjustable" ones too which are basically longer but have 3 holes on them so you can pick where to mount them Quote Link to comment Share on other sites More sharing options...
