Replacement air filter
Sandy
how many miles has your Z done firstly, Spark plugs don't need changing that often on the Z
If keeping with the panel filter then I'd recommend a K&N one. You then can clean this each service with a recharge kit and not have to buy a replacement filter
  martinmac said:
The plugs should be good to 50k but check with the traders, they will give you advice and a good price. :)
Indeed, but Phil used to change his earlier as he said they were properly dead by 50k. Not a bad idea to change plugs if you have the time and dosh to do it, cant do any harm :)
K&N filter is a good bet too.
