nicon2k Posted June 25, 2009 Share Posted June 25, 2009 A rattle has developed in my car that is bugging the s**t outa me. I am pretty sure its coming from the plastic triangle at the from of the drivers window, where the wing mirror mounts. Does anyone know how to remove the plastic cover? Quote Link to comment Share on other sites More sharing options...
nicon2k Posted June 25, 2009 Author Share Posted June 25, 2009 anyone? Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 25, 2009 Share Posted June 25, 2009 never heard of anyone or any known issues with the windows bud, sorry i cant help, hope someone comes along soon Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 25, 2009 Share Posted June 25, 2009 Ditto, not heard of this before. I know a few have removed them to fit new tweeters, maybe they will be along soon and tell you how to remove them and then you can put foam tape all over the place and hopefully stop it! Quote Link to comment Share on other sites More sharing options...
R35LEE Posted June 25, 2009 Share Posted June 25, 2009 Nicon, does the rattle stop when you put your hand against it? If it does it probably has a snapped retainer clip if not then the tweeter could be loose. If it is a loud hollow metalic rattle it could be loose nuts on the window regulator studs. Lee Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 25, 2009 Share Posted June 25, 2009 Nicon, does the rattle stop when you put your hand against it? If it does it probably has a snapped retainer clip if not then the tweeter could be loose. If it is a loud hollow metalic rattle it could be loose nuts on the window regulator studs. Lee there ya go, top man lee Quote Link to comment Share on other sites More sharing options...
nicon2k Posted June 25, 2009 Author Share Posted June 25, 2009 Nicon, does the rattle stop when you put your hand against it? If it does it probably has a snapped retainer clip if not then the tweeter could be loose. If it is a loud hollow metalic rattle it could be loose nuts on the window regulator studs. Lee Thats its!!!!!! It only happens at speed. All it needs is a very light touch and it will stop. It does sound metalic! Quote Link to comment Share on other sites More sharing options...
R35LEE Posted June 25, 2009 Share Posted June 25, 2009 Ok mate, PM sent give me a call at 6 tonight when I finish work. It's an easy fix. Lee Quote Link to comment Share on other sites More sharing options...
nicon2k Posted June 25, 2009 Author Share Posted June 25, 2009 Ok mate, PM sent give me a call at 6 tonight when I finish work. It's an easy fix. Lee Thanks so much buddy. Might be a few mins after 6 depending on traffic! Also, the PM hasn't turned up?!?!? Quote Link to comment Share on other sites More sharing options...
xStric9x Posted June 25, 2009 Share Posted June 25, 2009 I put a thin piece of foam in the gap as a sort term fix Quote Link to comment Share on other sites More sharing options...
