Pimm Posted June 18, 2009 Share Posted June 18, 2009 I decided to clean my pop charger as it was full of bits inside so i went and got the K&N serviceing kit. I washed the filter out last night and it was very dirty and then pre-oiled the filter. I guess using the K&N one if fine ? I have not started the engine yet as for no reason but myself i am a little worried it might be the wrong oil Is the above ok, if not what else can you use to re-oil. Thanks Quote Link to comment Share on other sites More sharing options...
sunset350z Posted June 18, 2009 Share Posted June 18, 2009 If its good enough for the K&N then its fine for the JWT Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted June 18, 2009 Share Posted June 18, 2009 Do these cars suffer from MAF (Mass AirFlow sensor) fouling after filter re-oils? The oil destroys the MAF on some cars by burning on deposots and causes all sorts of trouble. The solution is to remove the MAF for the first few hundred miles so the excess oil can be sucked out. Sorry Pimm, just asking, I'm sure it is fine really Quote Link to comment Share on other sites More sharing options...
M13KYF Posted June 18, 2009 Share Posted June 18, 2009 used the K&N stuff on my K&N filter and had no issues with the MAF sensor. Not sure removing the MAF sensor for a few hundred miles is a good idea. Its there for a reason. Quote Link to comment Share on other sites More sharing options...
jerry3167 Posted June 18, 2009 Share Posted June 18, 2009 I will be removing my dirty JWT filter very soon, replacing with a brand new filter, will wash and re-oil the old one ready for next time! Quote Link to comment Share on other sites More sharing options...
Pimm Posted June 18, 2009 Author Share Posted June 18, 2009 Well all good so far. But one job leads to another On inspection i noticed a little gap where the pop charger fits on via 4 bolts, one of them looked a little undone hence a tiny gap on the seal as i could see daylight through it so i tightend one and then the loose one and it broke off sometimes i wish i did not even bother but i do have two spare bolts so on another day i will have to take it all off and drill out the sheared off bolt and put another one in its place Hay Ho........ Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 18, 2009 Share Posted June 18, 2009 used the K&N stuff on my K&N filter and had no issues with the MAF sensor. Not sure removing the MAF sensor for a few hundred miles is a good idea. Its there for a reason. +1 - no oil fouling issues. The issues normally arise from over oiling. Make sure you dont put too much on (follow the instructions) and all will be well. I have reoilled my pop charger 3 times now (that I remember!) and havent had any issues so far. Quote Link to comment Share on other sites More sharing options...
AndWood Posted June 18, 2009 Share Posted June 18, 2009 How often should you clean and oil the JWT? Quote Link to comment Share on other sites More sharing options...
Carbon Coops Posted June 18, 2009 Share Posted June 18, 2009 i do mine every service Quote Link to comment Share on other sites More sharing options...
jim Posted June 18, 2009 Share Posted June 18, 2009 Any recommendations as to where to buy the K&N servicing kit? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted June 18, 2009 Share Posted June 18, 2009 i do mine every service +1 mine said every 10,000km, but hey, once a service will do! Quote Link to comment Share on other sites More sharing options...
Pimm Posted June 18, 2009 Author Share Posted June 18, 2009 Any recommendations as to where to buy the K&N servicing kit? You can get the K&N and pipercross at Halfrauds for £12.99 Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 19, 2009 Share Posted June 19, 2009 Any recommendations as to where to buy the K&N servicing kit? Hi Jim, Just added it to the website, £10.40 so a little cheaper than Halfords http://z-store.co.uk/index.cfm?fuseaction=product.display&product_ID=9382 Regards, Gaz Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted June 19, 2009 Share Posted June 19, 2009 i do mine every service +1 mine said every 10,000km, but hey, once a service will do! Oops, I thought they were more like 30K. Better do mine too! Quote Link to comment Share on other sites More sharing options...
Pimm Posted June 19, 2009 Author Share Posted June 19, 2009 Any recommendations as to where to buy the K&N servicing kit? Hi Jim, Just added it to the website, £10.40 so a little cheaper than Halfords http://z-store.co.uk/index.cfm?fuseaction=product.display&product_ID=9382 Regards, Gaz Hi Gaz, Never relised mate you done that otherwise i would of ordered off you. Quote Link to comment Share on other sites More sharing options...
jim Posted June 19, 2009 Share Posted June 19, 2009 Any recommendations as to where to buy the K&N servicing kit? Hi Jim, Just added it to the website, £10.40 so a little cheaper than Halfords http://z-store.co.uk/index.cfm?fuseaction=product.display&product_ID=9382 Regards, Gaz Tried to order it from your site, but didn't meet the minimum order requirement of £15. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted June 21, 2009 Share Posted June 21, 2009 Tried to order it from your site, but didn't meet the minimum order requirement of £15. Oops! I've changed that now! Never had that problem before because the cheapest item before was £15 Gaz Quote Link to comment Share on other sites More sharing options...
jim Posted June 21, 2009 Share Posted June 21, 2009 Tried to order it from your site, but didn't meet the minimum order requirement of £15. Oops! I've changed that now! Never had that problem before because the cheapest item before was £15 Gaz Thanks Gaz. Order now placed. Cheers. Quote Link to comment Share on other sites More sharing options...
