dcash5 Posted June 17, 2009 Share Posted June 17, 2009 Right I have been getting quite intermate with my head lights recently due to a few issues with a second set I was installing so I thought I would pass on my knowledge First of all ... The UK Headlights have an 8 pin connector block The JDM/US lights have an 6 pin connector block therefore they are not a direct plug and play swap The difference is that that the UK lights use a self leveling system (red and blue wires) where as the JDM/US uses a manual system On the JDM/US lights the 6 pins/wiring is arranged in the following configuration (diagram is looking from the wire side of the block not looking at the pins) The Red and Black wire on the top row goes directly to the Xenon invertor and they are slightly thicker as there are two black wires (its Obvious when you see it) Here a paint version of the JDM headlight wiring loom [ The bulbs are: Indicator: 20mm wedge (commonly known as a T20) Side Light: 10mm Wedge (commonly known as a 501) Xenon Headlight bulb: ( 35w D2R) Stock rating is 4600k The higher the K (kelvon) rating the bluer the bulb (not any brighter as most people think) High Beam bulb: H7 55w The fuses are located in the fuse box behind the battery. There is a multitude of fuses 1x 15amp per Xenon bulb (dipped) 1x 10amp per halogen (High) Note the rest of the cluster can work with a single fuse blown as the fuses are per bulb, (confused me for a while). Displays symptoms of a blown bulb. Just thought some of this info might be useful for someone one day Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted June 17, 2009 Share Posted June 17, 2009 i've just got some ballasts and igniters to replace the damaged ones i have, i got them in the states, will this affect them, as i'm not sure which bits your plugging or unplugging. i'm fairly certain the bit i have only controls the current to the HIDs i don't think it affects the self levellers. Quote Link to comment Share on other sites More sharing options...
dcash5 Posted June 17, 2009 Author Share Posted June 17, 2009 Im im sure they are the same accross the range, Certainly the same bulbs/ ballasts and ignitors between the JDM and UKs, completely interchangable Quote Link to comment Share on other sites More sharing options...
jim Posted June 18, 2009 Share Posted June 18, 2009 That's a really helpful post. Thanks a lot. I hope I don't ever have to use it, but its reassuring to know you've checked all this out for us. Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 27, 2012 Share Posted February 27, 2012 The UK Headlights have an 8 pin connector block The JDM/US lights have an 6 pin connector block therefore they are not a direct plug and play swap The difference is that that the UK lights use a self leveling system (red and blue wires) where as the JDM/US uses a manual system Exactly. I need the plug circled in red below so I don't have to destory my current headlights? Wrecker wants me to buy the whole murano light I found locally for the single plug Is this what I'm looking for? http://www.ebay.com/itm/2x-Matsushita-N ... 35b5827e95 If so - anyone know where to source a genuine part rather than the Chinese rip-off? Quote Link to comment Share on other sites More sharing options...
Tankaction Posted July 12, 2012 Share Posted July 12, 2012 I have a 03 plate JDM and am currently trying to get continental headlights. I have asked some dealers and german scrappys and they stop talking to me the moment they find out I have a non European import. Apart from the difference in wiring will the headlight unit fit in my vehicle or do they differ in size and shape? One guy I spoke to said he doesn't have headlights for a JDM but he's happy to see if the euro ones fit/work for free, but his workshop is quite a distance so I don't want to waste his time/my petrol if they won't. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
