tannerian Posted June 16, 2009 Share Posted June 16, 2009 Hi All Only recently the Zed has started making a creaking noise from both sides of the rear suspension - has anyone else had this experience? Its only noticable when driving very slow - i.e backing off a drive, or manouvering onto a driveway etc. It will creak if you push the back end down by hand too. There appears to be nothing sinister going on back there and is performing well - could it be bushes drying out? If it helps, the car is only used approx once a week, and has only started doing this since the dryer / warmer weather Any suggestions? Thanks in advance Ian Quote Link to comment Share on other sites More sharing options...
Gilly199 Posted June 16, 2009 Share Posted June 16, 2009 Sorry to jump on i was about to ask this aswell lol. Same applies as said in the post above lol. I must appologise i don't have an explination for you though. Gilly Quote Link to comment Share on other sites More sharing options...
Rosssco Posted June 16, 2009 Share Posted June 16, 2009 My car does the same. I think it could be the rear anti-roll bar links. I was told one needed replaced when my car was serviced recently. I've got them (decided to buy a pair), but haven't had a chance to fit, so can't confirm that this is the cause of the noise... Ross Quote Link to comment Share on other sites More sharing options...
Renegade Posted June 16, 2009 Share Posted June 16, 2009 Odd mines started too.If I drive forward slowly and brake. The front dips a little then the back settles with a clunk, as though there is a golf ball in the cubby Quote Link to comment Share on other sites More sharing options...
marzman Posted June 16, 2009 Share Posted June 16, 2009 This has been discussed several times. Rosssco you are right - its the anti rollbar end links. They can be re-greased rather than replaced first as that usually cures the issue. Quote Link to comment Share on other sites More sharing options...
tannerian Posted June 16, 2009 Author Share Posted June 16, 2009 Thank you guys - helpful as ever. Oh, and thats not sarcasm, by the way!! Ian Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 16, 2009 Share Posted June 16, 2009 They can be re-greased rather than replaced first as that usually cures the issue. +1, worked for me Quote Link to comment Share on other sites More sharing options...
tannerian Posted September 15, 2009 Author Share Posted September 15, 2009 Spray grease worked a treat - thanks!! Quote Link to comment Share on other sites More sharing options...
narcotix Posted September 15, 2009 Share Posted September 15, 2009 I too have a similar problem ... but will be purchasing some spray grease at the weekend ... Thanks a lot guys! Quote Link to comment Share on other sites More sharing options...
Husky Posted September 15, 2009 Share Posted September 15, 2009 not expensive for new ones from nissan tbh, or i think someone sells uprated adjustable ones on here, maybe alex Quote Link to comment Share on other sites More sharing options...
Pimm Posted September 15, 2009 Share Posted September 15, 2009 Nissan ones are about £ 27 each. Spray grease will work only as a short term fix though. Quote Link to comment Share on other sites More sharing options...
M350ZB Posted September 19, 2009 Share Posted September 19, 2009 I used hard acting grease and have never had the problem since, give it all a good smoother then leave on for a few weeks, then tidy up if needs be, worked perfectly for me !!!!! Quote Link to comment Share on other sites More sharing options...
tmJak Posted September 20, 2009 Share Posted September 20, 2009 I replaced mine. Still have loads of noises from rear suspension tho, just some of them have stopped Quote Link to comment Share on other sites More sharing options...
