Dblock Posted July 9, 2009 Share Posted July 9, 2009 just out on interset how big is it back there im sure ive seen a photo. that made it look rather large.if it is small say less than half a cube +1 on a decnt 8" and give it amps Its not just the size of sub its the sub spec, e.g. an idmax10" or old school solobaric 10" will need less room then a DD9512 which can use up to 4cuft. Best thing to do is check minium and recomended sealed enclosure size when buying a sub, Also remember when chosing your enclosure its before sub displacement. One trick which im not sure you can use on a sealed but works well on a ported enclosure is wadding. It slows the air down making the sub think its in a bigger box but you lose 3db off the peak. Quote Link to comment Share on other sites More sharing options...
yokomo Posted July 10, 2009 Share Posted July 10, 2009 works sealed too . if your already working a set space then defiantly going to be choosing sub around your volume . ona side note has anyone tried these ?? http://www.caraudiodirect.biz/subwoofer ... s-rw6.html being only 6 ers they need just .3 cubes for the pair ported ! Quote Link to comment Share on other sites More sharing options...
Dblock Posted July 10, 2009 Share Posted July 10, 2009 works sealed too . if your already working a set space then defiantly going to be choosing sub around your volume . ona side note has anyone tried these ?? http://www.caraudiodirect.biz/subwoofer ... s-rw6.html being only 6 ers they need just .3 cubes for the pair ported ! I haven't heard them but i dont think they will be too good as the new boxster uses something like them and its sounds rubbish. Quote Link to comment Share on other sites More sharing options...
