Virbration when breaking - Advice needed
jimboz
Hi Peeps,
Recently purchased my Zed from a trader and one thing he did advise before I bought it is a small vibration felt when breaking at high speeds, well anything from 60MPH +. Braking at slow speeds is fine with no vibrations. He said he would replace the rear brake pads before picking it up. I've had the car just under a week and can still notice the same problem; it feels like its coming from the front wheels so im assuming the front brake pads need replacing. The car has 35k on the clock so I guess if they have never been replaced before its now a good time!
I wanted to know if anyone else has experienced this problem before and im hoping replacing the front brake pads will solve the problem. I have called up the dealer and booked it in for them to look at it but wanted your advice.
Usually its caused by pad material bonding to the disc. Can you see any outline of pads imprinted on the disc? I had this before and they just needed braking in again to get rid of it (burns off the bonded pad material).
Although some members have cured the problem by replacing their pads, it is normally the case that the discs are warped especially if you are getting the problem at high speed with light braking. Considering the car has done 35k I would take it back and the discs and pads done.
