nurrish Posted June 8, 2009 Share Posted June 8, 2009 No idea how one gets in but it looks rather good Anyone have any idea's on how to get in? Quote Link to comment Share on other sites More sharing options...
Jay Posted June 8, 2009 Share Posted June 8, 2009 Simple put poppers in the doors. Looks very smooth Quote Link to comment Share on other sites More sharing options...
nurrish Posted June 8, 2009 Author Share Posted June 8, 2009 Jay said: Simple put poppers in the doors. Looks very smooth So it would be operated solely by your key fob Quote Link to comment Share on other sites More sharing options...
Stew Posted June 8, 2009 Share Posted June 8, 2009 Ask Andy. He has this done! Quote Link to comment Share on other sites More sharing options...
Jay Posted June 8, 2009 Share Posted June 8, 2009 nurrish said: Jay said: Simple put poppers in the doors. Looks very smooth So it would be operated solely by your key fob Yeh mate its done by a fob, i think it can be a pain in the backside tho. As stew said Andy has done this so he will kno the ins and outs of it Quote Link to comment Share on other sites More sharing options...
Andy Posted June 8, 2009 Share Posted June 8, 2009 Keep up! Have just done this to mine! Have rewired the standard door solenoids that lock and unlock the door to now pop the door open so they now open using the standard key. Quote Link to comment Share on other sites More sharing options...
Jay Posted June 8, 2009 Share Posted June 8, 2009 Nice work andy Quote Link to comment Share on other sites More sharing options...
Maccaman Posted June 8, 2009 Share Posted June 8, 2009 Makes for a really smooth look Only question I would have is, what happens if your fob packs in? I suppose you have to make sure you have a working back-up. Quote Link to comment Share on other sites More sharing options...
3FIDDYZ Posted June 8, 2009 Share Posted June 8, 2009 Top work Mr Kudos Would love to do the TVR solanoid under the wing mirrors thing but I have seen one somewhere where the solanoid is placed behind the B pillar and you push that in a certain place to open... you would need to make sure the doors lock when you drive though like the BMW antihijack system or they may open at speed or when its very windy!... Quote Link to comment Share on other sites More sharing options...
Martin W Posted June 8, 2009 Share Posted June 8, 2009 What happens if you get a flat battery? Quote Link to comment Share on other sites More sharing options...
Andy Posted June 8, 2009 Share Posted June 8, 2009 I have a separate external power feed going to the positive terminal on the battery so can jump the car externally from a jump pack or another car etc. Quote Link to comment Share on other sites More sharing options...
Martin W Posted June 8, 2009 Share Posted June 8, 2009 Good Planning!! Quote Link to comment Share on other sites More sharing options...
Martin W Posted June 8, 2009 Share Posted June 8, 2009 But to jump it wouldn't you need to have the clutch pressed down? Quote Link to comment Share on other sites More sharing options...
Andy Posted June 8, 2009 Share Posted June 8, 2009 No, I can connect the jump pack or car to the external power cable then that would give enough power to pop the door then I am in and can pop the bonnet. Quote Link to comment Share on other sites More sharing options...
Martin W Posted June 8, 2009 Share Posted June 8, 2009 OK - sounds like something I might do now Where do you put the power inputs? Quote Link to comment Share on other sites More sharing options...
Ian Posted June 8, 2009 Share Posted June 8, 2009 I think it looks wrong I quite like the handles on the Z Quote Link to comment Share on other sites More sharing options...
Andy Posted June 8, 2009 Share Posted June 8, 2009 It's just loose at the moment as I need to wire it in properly but I think it will end up being hidden behind the front number plate. Quote Link to comment Share on other sites More sharing options...
dcash5 Posted June 8, 2009 Share Posted June 8, 2009 Basically Andy's car will look like one of those AA vans where they can plug a set of jump leads in the front without popping the bonnet ha ha Quote Link to comment Share on other sites More sharing options...
Cragus Posted June 8, 2009 Share Posted June 8, 2009 A zed without it iconic door handles is like a smoke without a pancake! All wrong that means (if you have not seen austin powers!) Quote Link to comment Share on other sites More sharing options...
bronzee Posted June 9, 2009 Share Posted June 9, 2009 Andy said: It's just loose at the moment as I need to wire it in properly but I think it will end up being hidden behind the front number plate. If some cheeky toerag stole your front plate, would they be able to see the button or however you're going to do it? Quote Link to comment Share on other sites More sharing options...
M350ZB Posted June 9, 2009 Share Posted June 9, 2009 bronzee said: Andy said: It's just loose at the moment as I need to wire it in properly but I think it will end up being hidden behind the front number plate. If some cheeky toerag stole your front plate, would they be able to see the button or however you're going to do it? Knowing Andy, i dont expect it to be just hanging there, out in the open, im sure he if not all ready has thought of that , think its one of them things, what you might like more seeing it with no handles in the flesh, if you know what i mean Quote Link to comment Share on other sites More sharing options...
Andy Posted June 9, 2009 Share Posted June 9, 2009 bronzee said: Andy said: It's just loose at the moment as I need to wire it in properly but I think it will end up being hidden behind the front number plate. If some cheeky toerag stole your front plate, would they be able to see the button or however you're going to do it? It wouldn't be a button but just a charging point so you still can't get access to the car unless you have the key. Quote Link to comment Share on other sites More sharing options...
Rob_Quads Posted June 9, 2009 Share Posted June 9, 2009 3FIDDYZ said: Top work Mr Kudos Would love to do the TVR solanoid under the wing mirrors thing but I have seen one somewhere where the solanoid is placed behind the B pillar and you push that in a certain place to open... you would need to make sure the doors lock when you drive though like the BMW antihijack system or they may open at speed or when its very windy!... Yup it sounds like a really cool mod....until you have to live with it. I've done this to a previous car and while its rather cool and you get some quisicle looks when you open the door it can be a real pain in the air. When its posssing it down with shopping/bags its soo much easier just to open the door normally. IMO I would only do this mod to a proper show car, def not a daily driver otherwise it will drive you mad like mine did. Quote Link to comment Share on other sites More sharing options...
sunset350z Posted June 9, 2009 Share Posted June 9, 2009 A zed with ne door handles is like a woman with no t*ts Quote Link to comment Share on other sites More sharing options...
Andy Posted June 9, 2009 Share Posted June 9, 2009 I can fully understand where you are coming from Rob. My Z is now a weekend toy in all honesty. I have a Mondeo for the Tesco's run etc! Quote Link to comment Share on other sites More sharing options...
