Martin W Posted June 5, 2009 Share Posted June 5, 2009 Is there a trick to get your Vista laptop to recognise the Digicam I'm connecting a Sony DCR-PC53E VIA a handycamStation & Firewire lead (DV OUt) Windows beeps when i power on the Camcorder But Windows Movie maker doesn't recognise a device when I 'File | Import' Any ideas? Quote Link to comment Share on other sites More sharing options...
AK350Z Posted June 5, 2009 Share Posted June 5, 2009 If it's a Sony, it might be recorded in a proprietry MP4 format like that ATRAC they used on Minidiscs. Have you downloaded a codec pack recently? It will add recognition for loads of music and video formats. Quote Link to comment Share on other sites More sharing options...
Martin W Posted June 5, 2009 Author Share Posted June 5, 2009 Its more a case of getting the PC to see the Digicam first, never mind the stuff on it!!!! Quote Link to comment Share on other sites More sharing options...
AK350Z Posted June 5, 2009 Share Posted June 5, 2009 Are you running XP SP2? there's somthing on the Microsoft Knowledge Base: SYMPTOMS After you update your computer to Microsoft Windows XP Service Pack 2 (SP2), the performance of your 1394a or 1394b FireWire devices may be greatly decreased. A digital camera that uses S400 speed is an example of such a device. CAUSE This problem occurs if you connect a 1394a or 1394b FireWire device to a 1394b port. This problem occurs because Windows XP SP2 changes 1394b ports to S100 speed when you upgrade read more at: http://support.microsoft.com/kb/885222 The article gives a registry fix if you have this problem, with a download repair. here is the link to that download http://www.microsoft.com/downloads/details.aspx?FamilyId=CA0F2007-18B5-4112-8BD6-8BF4BD3130B9&displaylang=en Quote Link to comment Share on other sites More sharing options...
AK350Z Posted June 5, 2009 Share Posted June 5, 2009 Or even: I found this info on Sony's web site Knowledge Article C111893 http://esupport.sony.com/perl/model-faq.pl?mdl=DCRTRV330 How to connect a digital camcorder to a computer using an i.LINK® connection (IEEE 1394). Follow this procedure to connect a digital camcorder to a computer using an i.LINK® connection (IEEE 1394). IMPORTANT: The computer must have an i.LINK® (IEEE 1394) port and compatible video capture software installed. NOTE: The i.LINK® ports may have four or six pin connections. Sony® digital camcorders use i.LINK® ports with four pins. Consult the computer or capture card manufacturer for the specifications of the i.LINK® port on the computer. Verify that the tape that is being used actually has video recorded on it, and that it is rewound. Connect the i.LINK® cable to the digital camcorder. Connect the other end of the i.LINK® cable to the computer. Turn on the computer. Turn on the digital camcorder. Start the video capture software on the computer. NOTE: Image capture should be available if the computer hardware and software are configured correctly. If image capture is not available, consult the computer or capture card manufacturer for assistance. Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted June 5, 2009 Share Posted June 5, 2009 It does say Vista laptop in the first post. I'm sure a solution will be found amongst you IT people Quote Link to comment Share on other sites More sharing options...
Martin W Posted June 5, 2009 Author Share Posted June 5, 2009 Seems a minefield Sony Memory stick is recognized over the USB connection, but apparently not the DV tape. using 4 pin Firewire cable gets me a beep (from Device manager) on connection, but Device Manager refuses to list the device Quote Link to comment Share on other sites More sharing options...
